Help wiring passport 8500 x50
Old Jun 7, 2004 | 08:12 PM
ad350's Avatar
ad350
Default Help wiring passport 8500 x50
I can't figure out why my radar doesn't work using a stripped phone cord. The phone cord has four wires.........red, black, green, and yellow. I assumed the red and black were the ones to use and it didn't work. Then, I used the black and green and black with yellow. But, still not working. So, I read the thread with the diagram of the phone cord and used the two wired described on the diagram and still doesn't work. Anybody know what I am doing wrong. I hooked it up to a power and ground that I know works for sure.
Old Jun 8, 2004 | 08:21 AM
jikman01's Avatar
jikman01
Are you using the middle two wires of the four from the stripped phone cord? Phone cords could vary with wire color, but for sure it's the two middle wires of the four. Match these two to the pins in the diagram that you are refering to in another thread here called "Passport 8500" or something like that, BUT reverse what the diagram is telling you as it is not correct. I had the same problem that you are having. Also note that you have to turn the key past the first stop to the second one (there's one, two, then the car starts) for the radar to turn on.
Hope that helps.
Old Jun 8, 2004 | 12:16 PM
Vlad's Avatar
Vlad
Did you tried to turn the ignition on? If you wiring to cig lighter, than car should be on.
Old Jun 8, 2004 | 04:09 PM
ad350's Avatar
ad350
I will try flipping the two middle wires to see if this works. Hope it works.
Old Jun 8, 2004 | 04:27 PM
ad350's Avatar
ad350
It works! Thanks for your help
Old Jun 9, 2004 | 05:38 AM
jikman01's Avatar
jikman01
Glad I could help!
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
