i want to keep the stock headunit, but i have subs and an amp from my last car and i would like to put them in, how would i do that, is it possible to keep the stock unit,
Use an amp that accepts high level inputs. OR there is a conversion that converts your speaker wires into rca's. I think this piece can be bought at radio shack.
Originally posted by 04z33kid so, does it have the direction on how to conect everything when you buy the line coverter?
and how hard do u think it is?
thanks
just get a line converter. You only need one since the sub is mono. Should have 3 wires, 2 for a speaker lead and one for ground (not necessary). It's easier to tap from the rear speaker, but you'll have to pull a few panels off (which I assume you will to install the amp and sub).
Not too hard, but do a search and you'll see more pictures and details on Line Converter and sub installs.
