HELP! OEM Sat Radio antenna location
Has any one relocated, modified or replaced with after market, their OEM satellite radio antenna location? I understand all 04 Touring, Boze equipped,Z's are prewired for the OEM setellite tunner. I would like to take advantage of this EZ install but the antenna location is unacceptable to me. The tunner is a simple plug and play through the stock radio harness located in the right rear of the car,but I need a better option for an antenna/reception location, either stock or aftermarker. And does anyone know if any aftermarket antenna will work with the stock tunner unit?
[QUOTE]Originally posted by lawnmore
If you are talking sat.radio (XM,SIRIUS) it does not matter what h/u it is as long as the unit will support sat. radio.
Originally posted by BLACKZTRACK
I put mine here [/QUOTE
Thanks for the reply,but I dont see a Boze HU and thats what I have to interface with.
I haven't finished wiring mine yet, but I just mounted the antenna in the hole I had plugged when I shaved the rear wiper and spray nozzle. looks pretty good, imho. The wires go through the hole in the glass.
Put it on the strut bar in the back UNDER the plastic trim on top. The black plastic trim on each side of the silver Z will pop off and the small antennas will fit right under so you can snap it back on. The reception is great.
lawnmore, I get what you're saying - first off here's a link for the product: http://www.leeauto.com/parts/350z.html
But if you're talking about splicing the antenna I'm pretty sure you ought to be able to do it just fine. Just get a Terk antenna and splice the wires off it to your OEM sat kit. I've never seen this done however. You might want to ask about it on http://www.xmfan.com
Good luck!
Good luck!
Good luck!
Good luck!
Thanks for careful reading and the great links and splicing idea !!!
Originally posted by ddang1
The splicing thing is not recommended even if you get it to work because its not just like vehicle antenna wire which is easily able to splice. the XM antenna is a coaxial and a very small one at that if you try to slice it open you are bound to just snap it. If you can wait till november XM Direct will be out and you can use the universal tuner to hook up to your Bose unit from an adaptor plus you can use Terks mini mirco antenna which is tiny. Gonna cast about $150.
With Sirius you cant put the antennae there.I wanted mine there and was told theres no room in there.At least thats what they told me.
I have the kenwood sr-22 antenna I believe. Works fine for me.
Tochigi_236
Sep 27, 2015 03:40 PM
