Carpeting a box
Old Sep 16, 2004 | 09:00 PM
tractng's Avatar
tractng
Default Carpeting a box
Guys,
I bought some carpet for a sub enclosure. I have some nail glue. How do the profesionals connect two pieces? Is the process the same as those who install home carpet?
Tony
Old Sep 17, 2004 | 12:34 AM
OgreDave's Avatar
OgreDave
Overlap the edges and make sure its tight, then cut hard enough down through both layers to create a perfect seam, then fuzz by hand when it's dry ..
Old Sep 20, 2004 | 07:18 AM
dannichols's Avatar
dannichols
When you say Fuz, that means take off the excess fuzzy material that has come loose while gluing?
Old Sep 20, 2004 | 08:56 AM
Zrated's Avatar
Zrated
I can tell you what I did for my amp rack. I used a spray adhesive on the rack and the back of the carpet. Then I used a staple gun around the edges underneath where you can't see. It worked out great. I bought the spray adhesive at Pepboys, and it worked perfectly.
Old Sep 20, 2004 | 02:05 PM
Zrated's Avatar
Zrated
Oooops saw you had a fiberglass box, No staples.
Old Sep 20, 2004 | 02:43 PM
AV630's Avatar
AV630
#m Spray Adhesive is what you need to use. let it tack up a little bit and it will apply right on.
Old Sep 20, 2004 | 11:51 PM
OgreDave's Avatar
OgreDave
Fuzz as in rub .. the material will sort of hide your line. The key is of course making sure you have it pulled tight & cutting the 2 layers as even as possible.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
