Quick installation help requested
I found an extra sub concealed in the garage and decided to replace the bose to get some more temporary bass until I get my full system. I took some pictures to help. Do I just drop the new sub where the Bose was? What's the easiest way to install (I've never done anything audio)? Do I just take the black thing off the Bose and put it on the new one?
Here are the pictures, thanks for the help
New one:
Bose:
Again, thanks in advance for the help.
New one:
Bose:
The only problem I can forsee is that the impedance levels will not match. From what I understand the BlOSE sub is one ohm whereas you sub appears to be a 4ohm single voice coil. If you install it, the higher impedance is going to make the sub sound a lot weaker. Try it out if you like, but I would not recommend it.
