Stereo installation
Old Sep 20, 2004 | 06:31 PM
tractng's Avatar
tractng
Default Stereo installation
Guys,
How long does it take to install a stereo?
My stereo (alpine 9833) will arrive tomorrow. I was going to wait until the weekend comes, but now i am anxious to install. I get home from work at 8:30p.m. I figure, if i start at 9p.m., will i be done before 12 .
I have the amps wired already (including direct line).
What do you think? I also have the kit/wiring harness.
Thanks,
Tony
Old Sep 20, 2004 | 08:09 PM
mofoz's Avatar
mofoz
honestly its not gonna take that long, just make sure you test it before you reassemble the center console. I had never taken apart the console before, and by following the easy setps on the sticky at the top of the page, i was able to swap dash kits in 30min. and 15min was speant getting the metra kit off. Make sure you undo the negative terminal.
Old Sep 20, 2004 | 09:53 PM
hndumafia's Avatar
hndumafia
installing a h/u is very simple and will not take you long. most of the time is just wiring the harness and installing the dash kit. like mofoz said it can be done in >1 hour.
dont forget to take out the cd in your stock h/u if you have one in.
Old Sep 21, 2004 | 06:23 AM
Poison123's Avatar
Poison123
Google Bot
Do you have to disconnect the battery when your doing the install for just a HU?
Old Sep 21, 2004 | 07:31 AM
Rahtok's Avatar
Rahtok
Not as long as you _don't_ disconnect the little white box that the A/C controls plug into. If you do that, your SES light will come on.
Old Sep 21, 2004 | 07:35 AM
Poison123's Avatar
Poison123
Google Bot
Ok, hmmm so if I don't disconnect anything other than the wiring going into the stock HU I don't have to screw with the battery terminals at all then?
Old Sep 21, 2004 | 07:51 AM
Rahtok's Avatar
Rahtok
Assuming that you're not running amps, new wire for speakers, etc, yeah, that'd be fine. However, it gets pretty tight in there with the white box in the way. If you are going to disconnect the white box, disconnect your negative battery terminal, cuz then you won't make the same mistake I did and **** off your Z ECU.
Old Sep 21, 2004 | 08:01 AM
Poison123's Avatar
Poison123
Google Bot
Sounds like I should probably just disconnect it anyway to be on the safe side.
Old Sep 21, 2004 | 08:50 AM
dannichols's Avatar
dannichols
Be careful while your batt is disconnected. I have a 4 gauge wire with fuse running from the + post for amps. I had the fuse out of it and somehow the + end came close enough to cause a spark gap with my - terminal. Melted half the batt terminal before I had a chance to push it away (about 1 second).
Old Sep 21, 2004 | 09:01 AM
Poison123's Avatar
Poison123
Google Bot
Ick, thats gotta suck
Old Sep 21, 2004 | 10:21 AM
Poison123's Avatar
Poison123
Google Bot
Another question, can I just tap the wires on the new harness for power to other things. I plan on doing whats in this link for my ipod in the Z and eventually creating a little Carbon Fiber Cradle for it.
http://www.mindspring.com/~pmbenn/iPod/cable.htm
Old Sep 21, 2004 | 10:59 AM
tractng's Avatar
tractng
Rahtok,
Thanks man. Thats good to know. I was going to do it without removing the battery.
On a side note: I run my 4 gauge to the battery already, but have not connected to the battery yet. Do I connect the gauge to the postivie terminal while the negative terminal is unpluged too?
Also do I put the fuse in before the connection or do I put the fuse once the gauge is connected to the battery?
Any comments??
Thanks in advance.
Tony
Old Sep 21, 2004 | 11:28 AM
Rahtok's Avatar
Rahtok
Don't disconnect the + side, disconnect the - side and it'll be easier to avoid such mishaps.
Old Sep 21, 2004 | 11:32 AM
Rahtok's Avatar
Rahtok
Remove the fuse from your amp kit, connect your amp wire to the spare terminal on the battery. It'd prolly behoove you to have the other end of your amp kit hooked up to your amps already as well, but that's not such a big deal.
Old Sep 21, 2004 | 11:54 PM
tractng's Avatar
tractng
Guys,
My stereo came tonight, but i didn't have time to install it. Any ways, does the stereo fuse burn often?
The alpine 9833 has a fuse holder. I was thinking if a fuse burn, you will have to remove the dash out to just replace the fuse?
Tony
Old Sep 22, 2004 | 06:29 PM
nissan_fanatic's Avatar
nissan_fanatic
You didn't removed the - terminal and if you did you must have a cap or something that was holding the negative charge b/c that is the whole reason for removing the - terminal, so nothing is live anymore, regaurdless of the fuse.
Old Sep 22, 2004 | 06:34 PM
nissan_fanatic
Originally posted by tractng
Guys,
Tony
Better to replace a $.15 fuse than a $400 radio. Seriously, it shouldn't go out and unless you touch some wires together or something. The fuse is only there as a safety valve, so what ever was going to fry your stereo just frys the fuse instead. I wouldn't think twice about that fuse again unless you ever need to check it in the future b/c you stereo just completely died but I would check the radio fuse in the fuse box first, then all your other connections.
Old Sep 22, 2004 | 11:09 PM
tractng's Avatar
tractng
Guys,
Can you please confirm if this is correct.
I have the Scosche wiring harness (NN03b). I have an Alpine 9833 HU.
The following wires are not being used from the Scosche are:
1. Remote turn 12v+ (Cause I will be using the one from the HU instead). This is for my two amps
2. Ground for chasis 12v- (Cause I will be using the one from the HU).
3. Amplifier ground.
Is the above correct?
Also, can somebody explain what illumination/dimmer does? I think it has to do with when the headlights are on, it will adjust the brightness accordingly?
On a side note - I am using a ANL fuse holder (100amps). That suckher is so big, about 5-6 inches long. Where do I find the place near the battery? I have a fuse holder that is smaller (80amps), and my total amps is 90 for my two phoenix golds. Do I have any problem if I use the latter one?
Thanks in advance.
Tony
Old Sep 23, 2004 | 11:53 PM
tractng's Avatar
tractng
Rahtok,
I just installed my HU. I disconnect the neg. terminal and my SES light still went on.
How do I reset that?
My HU is an alpine 9833. So many features, I don't know how to tune it yet. My bass is not that good. I have two amps, Phoenix 5.0:1 & 5.0:4.
Sub is Infinity Perfect 10.1d
Tony
kyin
Oct 15, 2015 05:54 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
