Poor Antenna Reception Fixed
Old Sep 29, 2004 | 04:37 PM
studlee's Avatar
studlee
Lightbulb Poor Antenna Reception Fixed
Well, I have finally stopped searching for a satellite radio solution. I figured out why my aftermarket head unit got such crappy FM/AM reception.
It turns out that the antenna is amplified a bit, and you need to give it some power. So that little blue wire with a white stripe on it that comes on the harness..... connect that to your remote turn on. The reception becomes better than the average radio. I hope this helps, I know I listen to the radio without frustration now
Old Sep 29, 2004 | 05:36 PM
tractng's Avatar
tractng
Default Re: Poor Antenna Reception Fixed
Studlee,
Did you use an aftermarket wiring harness. If so, it should go onto the power antenna.
Tony
Old Sep 30, 2004 | 07:51 AM
studlee's Avatar
studlee
Default Re: Re: Poor Antenna Reception Fixed
Originally posted by tractng
Studlee,
Tony
Yeah I used an aftermarket wiring harness from Scoche. I never hooked the blue/white stripped wire (power antenna) to anything because the antenna wasn't powered in the sense that it went up and down when the radio was on/off. But I found out the other day that it is powered as in "Amplified", and now I get great reception.
Old Sep 30, 2004 | 06:37 PM
sal1's Avatar
sal1
I hooked mine to the ACC, so it only comes on when the ignition is on. Same pricipal.
Uriyo_
Sep 8, 2021 08:46 AM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
