door speaker grille cut to install Perfect 6.1
Old Oct 3, 2004 | 06:26 PM
tractng's Avatar
tractng
Default door speaker grille cut to install Perfect 6.1
Guys,
Just want to know if you have to cut the inside clips of the speaker grille in order to fit the Perfect 6.1?
I cut the clips and now it doesn't stay in place (now it sticks out)
Tony
Old Oct 3, 2004 | 07:19 PM
Zlips's Avatar
Zlips
Mine sticks out a lil bit at the bottom, but it is not really noticeable unless your are looking for it.
Lips
Old Oct 4, 2004 | 05:13 AM
Zrated's Avatar
Zrated
I don't have Perfects, but I still had to shave the lower clips. I removed the pointed part, but still left the part that clipped on with no clearance issues. See if that will work for U. The grills aren't expensive to replace.
...and while your at it, experiment with opening the speaker holes on the grill you want to replace. I definately could tell a difference in sound by doing this. It just takes some time to do.
3vilbunny
Jul 18, 2017 05:10 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
