Audio Builds Audio projects and builds from my350z members
My SQ Install coming soon
Old Nov 26, 2007 | 07:30 AM
sirfatty's Avatar
sirfatty
Default My SQ Install coming soon
I would just like to say thank-you to my brother mike who pretty much built this system for me, and Ge|atinousFury for all of his help since our systems are very similar. Also a BIG thank-you to Bing from Simplicity in Sounds for all your help and working with me. Ill be upgrading to an optima yellow top once my current battery dies. Pictures will come during the install
Here it all is
Headunit
Pioneer Premier 980BT with Bluetooth and I-Pod Add-On's
Speakers
DLS Iridium 6.2 Component Set with Custom Kicks from my man Bing
Subwoofers
2x 10" Image Dynamics Q Series (IDQ) V2 D4s
Sub Box
Z Enclosures 2x 10" Sealed With 1.41^3 Ft Under Trunk Brace And Amp Rack
Amplifiers
Alpine PDX 600.1 & Alpine PDX 4.100
Kicker Wiring with the Big 3 in the engine compartment.
Old Nov 26, 2007 | 06:35 PM
Ge|atinousFury's Avatar
Ge|atinousFury
I've read nothing but great things about the IDQ subs, I'm sure 2 of them will give you some nice bumps
Also, I'd like to add bluetooth to my install but the Alpine bluetooth unit just sucks from the reviews I've read lol
Looks like it's gonna be a kickass system!
Old Nov 27, 2007 | 07:41 AM
sirfatty's Avatar
sirfatty
the pioneer one does decent for me. the auto connect doesnt work with my slvr but once its connected it does decent. i cant wait to get it all wired up come on 32 more days
Old Nov 27, 2007 | 09:32 AM
DVFlyer's Avatar
DVFlyer
Speed of White
I have two IDMAX12's and Bing thinks I'm crazy. It's definitely overkill (like that's a bad thing), so I would bet the two IDQ10's will be perfect for you.
Old Nov 27, 2007 | 09:53 AM
StreetOC192's Avatar
StreetOC192
I agree with Bing LOL
Old Nov 27, 2007 | 04:26 PM
Vestax's Avatar
Vestax
That is a very respectable list of equipment.
Old Nov 27, 2007 | 05:31 PM
Get_Zwole's Avatar
Get_Zwole
very nice system indeed you will be very happy with it i sure am
Old Nov 28, 2007 | 05:25 AM
sirfatty's Avatar
sirfatty
thanks all. ill make sure to post some pics. Im actually heading to home depot later today, how many gommits u think im gonna need
Old Nov 28, 2007 | 07:16 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Old Nov 28, 2007 | 07:26 AM
cbr900son's Avatar
cbr900son
Just pick up alot they are really cheap and better to have too many then not enough!
Old Nov 29, 2007 | 06:41 AM
sirfatty's Avatar
sirfatty
will do. As far as the amp mounting positions.
3 options
1) in the stock sub location
2) in the glove box location
3) upside down underneath the amp rack from z enclosures (my amps are small enough to fit their.)
I really use that space behind my seats up to the cross bar. and need to keep as much as possible. so i really would not like to put them on top of the amp rack plus it will conceal them not as flashy
Old Nov 29, 2007 | 07:21 AM
StreetOC192
1) Great place, easy enough to make an amp rack, plenty of airspace to keep things cool.
2) Ditto as for option 1, no need to really make an amp rack since you can mount them to the 'floor' of the glove box.
3) I would never recommend anybody mount their amps upside down. Amps are designed the way they are for a reason.....heat dissipation. You can cause damage to the amp by mounting upside down unless you make provisions for fans to continuously move air across the heat sinks.
Old Dec 2, 2007 | 02:23 PM
sirfatty's Avatar
sirfatty
ok im about to order 2 120 mm fans and wanted to know what they should be doing and where to locate them in the factory sub location. im planning on having one pull in the sub box and have one push it to the glove box area.
Good, Bad, recommendations
Old Dec 2, 2007 | 02:28 PM
Ge|atinousFury
PDX amps run relatively cool; Are you sure you need active cooling?
Also, are you trying to move cool air to cool the glove box or are you trying to exhaust hot air from the stock sub location?
For my install I am removing that plastic tray in the glove box and in the amp rack that I built there will be a hole in it to feed all the cables up through. This hole will also allow cooler air in from the rest of the car's interior. Granted, the hole is only 3" X 3" or so but I believe it will be adequate for the 2 PDX amps in there. Perhaps someone who actually runs amps in his/her glove box can chime in with some input.
Old Dec 2, 2007 | 04:37 PM
sirfatty's Avatar
sirfatty
I am running my amps in the stock sub location not the glove box. I probably dont need them, but since i am car iliterate, i would just assume pay the 40 bucks for 2 nice fans and get it installed.
Im playing the better safe then sorry card. Im asking what i should do
1) PULL PULL (cold air in)
2) Push Push (hot air out)
3) one PULL cold air in and one PUSH hot air out (im leading toward this one after talking to bing)
Old Dec 2, 2007 | 04:45 PM
Ge|atinousFury
Push-pull config (series) is better for high impedance (air resistance) environments, while push-push or pull-pull (parallel) is optimal for low impedance environments
I would assume that the rear glove box & stock sub location area have pretty low air resistance, as it is one big open area. Perhaps options 1 or 2 would be optimal in this case?
If it were me I'd do a pull-pull configuration, blowing cool air directly on your main heat source (amps). If you want to do the pull-push config it should work fine too...and you could maximize the cooling capability of the setup by positioning the "pull" fan as low as possible (to grab coolest air) and the "push" fan as high as possible (to exhaust warmest air).
Source: http://www.comairrotron.com/engineering_notes_02.asp
Old Dec 12, 2007 | 11:03 AM
sirfatty's Avatar
sirfatty
ok well ive gotten everything. just waiting on the custom kicks from Bing
Ill post pics before during and after the install
Old Dec 12, 2007 | 01:07 PM
rockinbboy's Avatar
rockinbboy
I read this thread too fast....thought it said MySQL install. I was seriously thinking WTF you need a SQL DB in your system for?
Old Dec 13, 2007 | 07:44 AM
james840a's Avatar
james840a
I have to agree, the Alpine Bluetooth unit sucks. The part that sucks about it is the list of phones it works with. If you have a Razr then its a great BT, but if you have a Blackberry pearl like me, it sucks, can only use it as HF and not full functions. Ended up getting an Parrot BT color HF
Old Dec 23, 2007 | 11:10 AM
sirfatty's Avatar
sirfatty
ok all just an update many pictures will be coming soon.
I have received my sub box form z enclosures, kicks from bing should be arriving very soon and i have almost completed my amp rack. pictures of everything plus the rest of the gear very soon
