RCA Cables
Old Apr 9, 2008 | 01:22 PM
sosojeffcc's Avatar
sosojeffcc
Default RCA Cables
So I was in a rush putting in my order for an amp, and ordered these rca cables as well without putting much research into wires. Did I just waste 25 bucks on these cables that would actually "perform" worse than any ol regular cables?
http://www.woofersetc.com/index.cfm?...roduct_ID=6301
Old Apr 9, 2008 | 06:57 PM
DHCrocks's Avatar
DHCrocks
they should be fine. Stinger makes good stuff although that is the lower line. What's important is that it's a twisted pair that's the most important thing to look for in a a set of RCAs, they help to minimize the amount of noise introduced into the system. The ends are not gold plated but that's not much a big deal, oxidation of the connection is not that big a problem. honestly, you really can't tell the difference between RCAs in an automobile, too much ambient noise to notice any subtle differences it might make.
Old Apr 10, 2008 | 04:40 AM
350zspl's Avatar
350zspl
it is stinger lower end , but still very good
the higher end stuff can get pricey like $ 150 for a set of 20 ft
you will be fine
Old Apr 10, 2008 | 04:55 AM
StreetOC192's Avatar
StreetOC192
Twisted pair is only effective in a balanced input configuration.
The route of the RCA and installation is more important than the quality of the cable unless you are running a VERY high end SQ system.
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
cashmoney03
Sep 27, 2015 05:24 PM
hulkout
Tuning
Sep 18, 2015 05:42 AM
