Audio Video Headunits, Monitors, Radar detectors, Subwoofers, etc...
FS: kenwood amp (NEW)
Old Feb 26, 2011 | 02:37 PM
fannin522's Avatar
fannin522
Default kenwood amp (NEW)
fs is the kenwood KAC-6404 i bought it for my car but ended up going with a different amp it is brandnew in the box im looking for 90$ shipped for it my loss is your gain
Adding an amplifier like the KAC-6404 can bring new life to any audio system. This 4-channel amplifier will dramatically improve sound quality with 500 watts of power and features like MOSFET switching and built-in variable low-pass and high-pass filters.
General Features
• 500 Watts Maximum Output Power
• CEA Rated: 40W x 4 (1.0% THD+N) (4Ohm)
• 60 Watts x 4 (2 Ohm)
• 130 Watts x 2 (4 Ohm Bridged)
• MOSFET power supply
• Preamp and speaker-level inputs
• Fuse rating: 25A x 1
• 13-3/4"W x 2-3/8"H x 9-1/8"D
Specifications
CEA-2006 Standard 40 W x 4
RMS Watts per channel @ 4 ohms, 1% THD+N
80 dBA Signal to Noise Ratio (Reference: 1 Watt into 4 ohms)
Max Power Output 500 W
Rated Power Output 14.4 V
40 W x 4 (4Ω) (20 Hz - 20 kHz, 1.0% THD)
60 W x 4 (2Ω) (1 kHz, 1.0% THD)
130 W x 2 Bridged (4Ω) (1 kHz, 1.0% THD)
Frequency Response 5-50kHz(±3dB)
Input Sensitivity 0.2 V - 5.0 V (MIN-MAX)
Input Impedance 10 kΩ
Signal to Noise Ratio 94 dB
Low Pass Filter Frequency (-12 dB/oct.)
50 Hz - 200 Hz (variable) Low-Pass Filter Frequency
High Pass Filter Frequency (-12 dB/oct.)
80 Hz (fixed) High-Pass Frequency
Dimensions (W x H x D) 330 x 59 x 230 mm (13 x 2-5/16 x 9-1/16)
Old Mar 3, 2011 | 08:25 PM
fannin522's Avatar
fannin522
bump make an offer or a trade want this gone
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
dcains
Nov 11, 2015 11:36 PM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
