Audio Video Headunits, Monitors, Radar detectors, Subwoofers, etc...
FS: Amps-n-stuff:Addictive, Crossfire, AudioControl, Alpine
Old Mar 24, 2011 | 04:05 PM
adamtaylorpcb's Avatar
adamtaylorpcb
Default Amps-n-stuff:Addictive, Crossfire, AudioControl, Alpine
ALL PRICES ARE OBO!!!!!!!!!!!!!!!!!!!!!!!
List of products:
Amps
1) Addictive Audio Elite Series 50.1
2) Crossfire XP1000D
3) Crossfire XP6004
4) Alpine PDX 4.100
5) Alpine PDX 2.150
Processing
6) AudioControl DQT
7) AudioControl DXS
AMPS
Addictive Audio
Elite Series 50.1
(These are some of the *****-iest amps i have ever used. this sounds more like a 1k than a 600. Addictive under rates the hell out of their stuff. Their FIX 500.1 "500 watt" amplifier will put out close to 9,000 wrms at 1 ohm yeah it does 500wrms... at 4 ohm . At daytona we were talking and they said the Excruci8 *250wrms 8"* had a true 1000wrms on it when they were benching it and it didn't even break a sweat. )
  • EASY CLICKİ on all Frequency Adjustments for Simple and Exact Tuning
  • Short Circuit, Thermal, Low/High/Reverse Voltage Protection
  • Clipping Circuit with LED Indicator
  • 1 Pair RCA Outputs
  • Phase Shift 0-180 Degrees
  • White or Blue Selectable Accent Light
  • EASY CLICKİ Selectable Center Point Frequency (20-85Hz) with Bass Boost up to +12dB
  • EASY CLICKİ Low Pass Filter: 50-250Hz
  • EASY CLICKİ Subsonic Filter: 10-55Hz (24dB/Octave)
  • 2 Amplifiers Can be Strapped Together with Provided Strapping Cable
Looking to get $300 + Shipping
MSRP $499
Crossfire Amps:
These do rated power at 13.8 volts and someone benched the xp1000d to do about 1300 RMS!
XP1000D
  • RMS Power @ 1 Ohm (13.8v): 1000x1
  • RMS Power @ 2 Ohm (13.8v): 500x1
  • RMS Power @ 4 Ohm (13.8v): 250x1
  • Input Sensitivity (x1): 0.13v-3.0v
  • Input Sensitivity (x3): 0.39v-9.0v
  • Variable Low Pass Filter (LPF): 50-250Hz
  • Crossover Slope: 18dB
  • Subsonic Filter: 20-50Hz
  • Preamp Line Output
  • Built in cooling fan
  • Strapable
  • Dimensions: 8.6"W x 2.8"H x 13"L
  • Military Spec Audiophile Grade Components
  • High Efficiency PWM Power Supply
  • Soft remote on/off circuitry
  • Optional Remote Subwoofer Level Control
  • Variable Lowpass Crossover
(in my car, pics soon)
Looking to get $350 + Shipping
MSRP $799
XP6004 Like new (actually may be, i have never used it and i dont think the previous owner did either)
  • 75 Watts RMS x 4 @ 4 Ohms @ 13.8V
  • 300 Watts RMS x 2 @ 4 ohms @ 13.8V
  • Bridgeable 4 Channel Amplifier
  • Switcheable rear 6db boost at 55 hz.
  • Variable 12db HPF/LPF crossover 50-500hz
  • Balanced Inputs
  • Input Sensitivity Multiplier Switch
  • Input Selector Switch (2ch/4ch)
  • RCA Pre-amp output
  • MOSFET power Supply
  • Nickel-Plated Connectors
  • Discrete Terminal Mount
  • 5-Way Protection Circuit
  • Power/Protection Indicator
  • Cooling Fan
  • 2 ohm stereo stable
  • S.M.D. Technology
  • 8.6"W x 2.8"H x 15.75"L
Looking to get $250 + Shipping
MSRP $599
Buy both for $500 + Shipping
Alpine:
Alpine PDX 4.100 = available but haven't had time to type this up
Alpine PDX 2.150 = available but haven't had time to type this up
Processing
AudioControl: (Only selling these because i got a MS8)
DQT
Digital Car Audio Equalizer
  • Stereo Design
  • Thirty Graphic Equalization Controls per Channel
  • Two Fully Adjustable Parametric Equalization Controls per Channel
  • 24 bit Digital Audio Processing
  • 8 User-Programmable Memory Settings
Like other digital car audio processors from AudioControl, the DQT is powered by a state-of-the-art audio 24-bit DSP (digital signal processor) specially designed for performance car audio systems. In addition all AudioControl digital car audio processors are designed and manufactured at our factory, located in the rainforest of the Pacific Northwest. The coffee is warm and the weather is cold!
MSRP $599
DXS
Digital Car Audio Electronic Crossover
  • Two Input and Six Output Channels
  • Three-way Digital Electronic Crossover
  • 24 dB per Octave Linkwitz-Riley Design
  • Output Level Controls
  • PFM Subsonic Filter
All AudioControl digital car audio processors are designed and manufactured at our factory, located in the rainforest of the Pacific Northwest. The coffee is warm and the weather is cold!
Looking to get $200 + Shipping
MSRP $499
DQT and DXS both for $400 + free Shipping (conus)
Old Mar 26, 2011 | 02:23 PM
adamtaylorpcb
up top
Old Apr 13, 2011 | 05:16 PM
adamtaylorpcb
ttt
dcains
Nov 11, 2015 11:36 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
Nazar
May 26, 2003 09:37 PM
toothlessracer
Mar 15, 2003 09:06 AM
dmcgibbo
Nov 30, 2002 10:11 AM
