Audio Video Headunits, Monitors, Radar detectors, Subwoofers, etc...
Cleaning out closet -lots of audio/gps/computer
Old May 24, 2011 | 07:05 PM
07_350z_JP's Avatar
07_350z_JP
Default Cleaning out closet -lots of audio/gps/computer
10” Memphis ----M1 SVC 4ohm 10” Modular $80 shipped
• •10" Single 4 ohm M1 Series Subwoofer
• •RMS/Peak: 300/600
• •High-density foam surround
• •Kevlar reinforced paper cone
• •Custom-cast vented "M" Basket
• •Voice Coil: Single 4-ohm voice coils
• •Sensitivity: 89 dB
• •Magnet Size : 66 oz.
• •Mounting Depth : 5.5"
MTX RT251D $80 shipped
  • 250W RMS MTX class-D technology with 85% efficiency
  • Performance certificate incorporated with each amplifier
  • Class-D mono block amplifier (1-channel) optimized for 2 Ohm use
  • Build using SMT (Surface Mount Technology)
  • Active x-over Low pass 18dB/Oct. @ 85Hz
  • Fullrange RCA line output
  • Pure N-channel V-FET output stage
  • High level input with "Smart engage"
  • PWM MOSFET power supply
  • Thunder EQ, selectable: 0, +6 or +12dB centered @ 40Hz
• RMS power @ 2Ohm : 1x250W
• RMS power @ 4Ohm : 1x125W
• Active Low pass x-over : 18dB - 85Hz
• THD+N : <0,2%
• Signal/noise : >100dB
• Frequency response : 20Hz - 85Hz (±1dB)
• Sensitivity : 0,1 to 8 Volts
• Damping factor : ≥100 (4Ohm, 100Hz)
• Thunder EQ : 0,+6 or +12dB @ 45Hz
• Dimensions : 20,4 x 24,8 x 5,3 mm
JL 500/1 V1 $170 shipped
• mono subwoofer amplifier
• 500 watts RMS x 1 at 1.5 to 4 ohms
• Regulated, Intelligent Power Supply system
• differential-balanced inputs
• variable low-pass filter (40-200 Hz, 12 or 24 dB/octave)
• parametric EQ bass boost (0-15 dB at 20-80 Hz)
• variable infrasonic filter (-24 dB/octave at 15-60 Hz)
• optional wired remote bass boost
• Class-D amplifier design
• MOSFET power and output stages
• speaker- and preamp-level inputs (speaker-level input requires an optional adapter)
• preamp outputs
• 4-gauge power and ground leads and a 50-amp fuse recommended — wiring and hardware not included with amplifier
• no onboard fuses — when installing multiple amps in a system, an additional 50-amp in-line fuse between the distribution block and the amplifier is recommended
• 13-7/16"W x 2-5/16"H x 10-1/16"D
Kicker IX252 $40 shipped
• •stereo or bridged mono output
• •Tri-way capable (Tri-Way crossover required)
• •frequency response 20-20,000 Hz
• •25 watts x 2 at 4 ohms
• •60 watts x 1 in bridged mode
• •30 watts x 2 at 2 ohms
• •requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
• •speaker-level inputs
• •MOSFET power supply
• •0-18 dB bass boost centered at 40 Hz
• •0-12 dB treble boost centered at 18,000 Hz
• •18 dB/octave crossover switchable at 70 or 110 Hz
• •dimensions: 6-5/16"W x 2-1/2"H x 9-1/2"D
American Pro VS-1403 $25 shipped
• VS-1403
• FOUR CHANNEL AMPLIFIER WITH BUILT IN LOW PASS FILTER
• MAXIMUM POWER OUTPUT
• 200W @ 2 OHM
• POWER OUTPUT:
• 25Wx4CH (@ 2OHM) (100W) LESS THEN 1% THD
• 15Wx4CH (@ 4OHM) (60W) LESS THEN 0.8% THD
• ALL MEASUREMENTS DONE @ 14.4VDC, 1KHz INPUT SIGNAL FREQUENCY RESPONSE 20Hz-20KHz
• THIS MODEL IS EQUIPED WITH:
• LPF (LOW PASS FILTER) VARIABLE 50Hz-250Hz
• HIGH AND LOW ADJUSTABLE LEVEL INPUT
• LED INDICATED POWER STATUS
• BUILT IN PROTECTION AGAINST SHORT CIRCUIT AND HIGH TEMP
• AUTO POWER ON/OFF BY REMOTE (+12V)
• DIMENSION: 11 1/8 (W) x 1 7/8 (H) x 6 3/8 (L)
Profile AP600 $70 shipped
• 2-channel car amplifier
• 100 watts RMS x 2 at 4 ohms (150 watts RMS x 2 at 2 ohms)
• 300 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
• variable filters (low-pass from 50-250 Hz, high-pass from 80-1200 Hz, at 12 dB per octave)
• variable bass boost (0-12 dB at 45 Hz)
• stereo or bridged mono output
• Tri-way capable (Tri-Way crossover required)
• preamp- and speaker-level inputs
• preamp outputs
• fuse rating: 20A x 2
• 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
• 10-11/16"W x 2"H x 10-5/16"D
Beltronics V 995 $98 shipped
• •digital voice and audio tone alerts for radar, laser, SWS, and VG2 detectors
• •Ku band for European driving
• •Shadow Technology™ keeps you invisible to VG2 radar detectors
• •360° laser protection
• •alerts you to the use of new POP radar
• •LED bar graph or tech display
• •software upgradeable
• •digital signal processing for superior speed and sensitivity
• •3 city and 1 highway modes
• •dimensions: 2-3/4"W x 1-1/4"H x 4-3/4"D
Compaq CQ60-615DX--perfect screen -stupid flash/dust $265 shipped
• Intel Celeron processor 900 2.2GHz / Intel Graphics Media Accelerator 4500M
• 15.6" Diagonal High-Definition HP BrightView Widescreen Display
• 2GB DDR2 SDRAM Memory / 250GB Hard Drive / 802.11b/g/n WLAN
• SuperMulti 8X DVD±R/RW with Double Layer Support
• Windows 7 Home Premium 64-bit / 6-Cell Lithium-Ion Battery
Garmin Nuvi 1300---- 2012 MAP LOADED-NEWEST --$90 shipped
Details:
• •portable GPS navigator
• •suction-cup windshield mount and dashboard disk
• •JPEG picture viewer
• •car power adapter and built-in rechargeable battery with 4 hours of life
Navigation features:
• 4.3" (480 x 272 pixels) display with touchscreen control
• •6 million points of interest
• •preloaded with maps for the lower 48 states, Hawaii, and Puerto Rico
• •voice prompts announce road names over the built-in speaker
• •allows custom points of interest
• •ecoRoute calculates a more fuel-efficient route
• •built-in travel kit including world clock, currency and measurement converters, calculator, and more
• •security feature allows you to disable most functions with a user-entered password
• •multi-destination routing: allows 1 stopping point
• •transport modes: auto, pedestrian
Expandability:
• •microSD card slot
• •compatible with MSN Direct content including traffic and weather (additional receiver and subscription required, but MSN Direct service will only be available through January 1, 2012)
• Other features and specs:
• •dimensions: 4-13/16"W x 2-15/16"H x 5/8"D
• •weight: 5.7 oz.
Old May 25, 2011 | 10:11 AM
07_350z_JP's Avatar
07_350z_JP
ok cleaned out my PM box - sorry it was full. I had 19 new PMs so who knows how many were missed/blocked.
try again -everyone else I responded. get this things out of here at these insane prices.
Old May 30, 2011 | 09:52 AM
07_350z_JP's Avatar
07_350z_JP
everything goes to ebay on friday.........
all the prices already include paypal fees and shipping in USA.
also forgot to add item
Iphone 3GS 16gb -black- minor back scratches no screen scratches.ATT -cleaned and ready to go $240 shipped
Old Jun 10, 2011 | 01:24 PM
morphiusrt's Avatar
morphiusrt
Still got the JL amp? pm me if so
Old Jun 11, 2011 | 09:45 PM
07_350z_JP's Avatar
07_350z_JP
sold everything on ebay for much more lol. close it up.Thanks!
Stevo Z
Oct 3, 2015 09:14 PM
_bit
Oct 2, 2015 07:49 AM
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
