Australia/New Zealand Queensland, South Australia, Victoria, New South Wales, etc.
My Wheel Alignment
Old Jan 26, 2004 | 09:56 PM
apsilon's Avatar
apsilon
I didn't realise you'd lowered your car. What did you use if you don't mind my asking?
Old Jan 26, 2004 | 11:43 PM
MR RIZK's Avatar
MR RIZK
H&R Springs for now and will move to coil overs later when there is more choice.
Old Jan 27, 2004 | 12:32 AM
DavidM's Avatar
DavidM
MR RIZK, and how much did you lower the car by in order to get -1.75deg of camber?
Old Jan 27, 2004 | 01:45 AM
MR RIZK's Avatar
MR RIZK
As mentioned on the last post first page.
About 15mm front and 30mm rear.
From memory it was -1.5 on one side and -1.75 on the other at the front.
Hope this helps. DavidM You have the Excede correct ? If so PM me please as I need to ask you a few questions.
Cheers,
Michael
Old Jan 27, 2004 | 03:20 PM
DavidM's Avatar
DavidM
As mentioned on the last post first page. About 15mm front and 30mm rear. From memory it was -1.5 on one side and -1.75 on the other at the front.
Thanks for the info ... I must have missed the post on the previous page. Though, it looks like dropping the car 15mm produces (about) extra -1deg of camber. That could be worthwhile looking into as it may be easier and more benefitial then the camber-kit at the front. I'll have to look into that.
Though, I am curious as to why you would lower the car more at the rear? I would have thought that it'd be detrimental to the handling (ie. less grip at the front) ... still, that's just speculating as I have not thought about it much.
I think you might have the wrong person as I don't even know what 'Excede' is.
Old Jan 27, 2004 | 06:15 PM
MR RIZK's Avatar
MR RIZK
The reason the rear dropped more is because H&R usually try to keep the car flat. The standard setup has the car leaning forward. I am in the process of chasing this with H&R as the US springs drop evenly but the EURO verison does not.
Old Jan 29, 2004 | 05:21 AM
KY350's Avatar
KY350
Excede is the aftermarket ECU and our fellow Northern Territorian has it - just can't remember his name.
Old Jan 29, 2004 | 06:27 AM
zuff's Avatar
zuff
Don't you mean Chiptorque's XEDE?
http://www.xede.com.au/
Old Jan 29, 2004 | 01:06 PM
harryw's Avatar
harryw
i think its Jacko, how very farkin Ozstrayin!
As always
H
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
