Solo2 BS car complete 3049 lbs
Originally posted by EnthuZ
Benny, Koni SA = Koni Yellows!
The DA's are coming from Truechoice (and thru BCR).
But isn't a DA a hair style from the '50's?
Originally posted by Vlad
Amuse TI Y-pipe
Jic TI exhaust
How much did it cost and how much weight did it shaved off?
Amuse TI Y-pipe
Jic TI exhaust
The Y-pipe only save 8-9 lbs if I cant get the amuse one fixed up right I'm goind to run the Jic one I have.
The exhaust saves alot. When you include the pipe it is around 70lbs.
The reason about the Y pipe not saving much is if you remove the shielding off the stock Y-pipe is only weighs 16 lbs.
Originally posted by benzz280
I see! By the way Bruce, i'll see you at BlackHawk on May 16, i just got the "lovely" email from our dear Mr Vatuk
What color Harness Bar should I reserve for you?
Don't you have to also run the same dia. and width as the stock rim? i.e: base, ethus. are 17'X7' on all 4 & Perf., Tour. are 18'X8' on all 4, yet the Track is 18'X8' front & 18'X8.5' rear. According to the rule book in stock class the rim must be identical to oem? Right?
And the OEM 17" wheels are 7 1/2" F, & 8" rear.
AND, I beg to differ with your signature.......
If can't figure it out, then maybe you shouldn't be on the track. A couple of issues back in SportsCar magazine for those who don't know - a sub. for SCCA members there was an article written by either Danny Shields or Randy Pobst about the difference between Auto-X and Road racing. For me track days are fun, a bit boring and repetitive which is much different than the excitement and challenge from Pro Solo or Solo II.
Looking forward to it. Are you going to bring your VERY cute girlfriend?
If i were to get one, it will definitely be a blue one, u know that
By the way, i noticed that Gingerman has test and tune days which cost about $60 for like 3 hours on certain days of the week, just wondering if Blackhawk has these as well?
Jim/Carter
We ended up with a reservation at a Days Inn, I believe there's some hotel discussion in this thread.
http://www.solo2.org/ubb/ultimatebb..../2/1982/2.html
SpartanZ32
Oct 22, 2015 09:36 AM
