SmartStrings
Do any of you guys here have any experience with Smartstrings for doing your own 4 wheel alignments? I figure I'll eventually get a camber gauge, but I need something to measure toe settings.
http://www.smartracingproducts.com/p...ccessories.pdf
Based on the way the system works, it'll probably take no more than an hour to make the adjustments. Most of it seems to stem from installing the appliance, measuring, lifting the vehicle, making adjustments, lowering the vehicle, remeasuring, and repeating the process until the desired alignment is attained.
With alignments running $70-$80 a pop, it's tough to experiment with settings on the Z. I figure I can also check and adjust alignment for all other vehicles in my garage too, and should pay for itself in two years (or less).
