Koni Sports problem
Old Jun 17, 2005 | 07:25 PM
DmanG281's Avatar
DmanG281
Default Koni Sports problem
Well after 2 months of driving the new off my car I finally got around to installing my 350evo front sway and Koni SA struts. The only problem I ran into is somewhat of a big one. After I was done with the install I weant to mess around with the damping **** and the right front strut would not budge at all. I loosened and re torqued everything to make sure something wasn't to tight and still nothing. So by this time I rounded the little adjustment **** and the nipple at the end broke off. I sent an e-mail to 350evo to see what they can do but I just wanted to see what you guys think about getting this strut warrantied?
Thanks
D
Old Jun 18, 2005 | 07:27 AM
C Ray Z's Avatar
C Ray Z
Default No Problem here
Sorry to hear this. I have run this setup for two years with now issues of adjustment or fit. Sorry I can not add any information other then I did not have this issue. I did not do the install.
Old Jun 18, 2005 | 03:51 PM
del105's Avatar
del105
15 f125
Thanks
D
If the vendor can't help you call koni. They seem very will to to help with problems. When you toque down top mount you should be touching the "nipple" at all. I don't know what you where holding it with I use an adjustable wrench, pliers will ruin them.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
