Popcharger Legal for B stock?
Old Jul 5, 2005 | 07:29 AM
Westby's Avatar
Westby
Default Popcharger Legal for B stock?
I'm making an order today for brakepads and need a new airfilter, I belive not until SP but I need a quick response ( btw I'm getting hawk HP pads and better suggestions? ) oh and finaly Pads are allowed rulebook says: Make and material of brake linings may be changed ( that means pads right? )
Anyway need to get this ordered so it will come in time to install.
Thx
Old Jul 5, 2005 | 07:38 AM
del105's Avatar
del105
15 f125
no
Old Jul 5, 2005 | 07:46 AM
del105's Avatar
del105
15 f125
I like this one
http://www.jscspeed.com/wrx/intake/p...pin_filter.htm
or this one
http://www.jscspeed.com/wrx/intake/b...pin_filter.htm
I know they say WRX but they fit the Z.
Old Jul 5, 2005 | 07:50 AM
Westby's Avatar
Westby
Default what about the pads?
I'm allowed pads right cause mine are cooked
Old Jul 5, 2005 | 09:00 AM
PedalFaster's Avatar
PedalFaster
Solo 2 rule book: http://scca.com/_filelibrary/File/2005SoloRules.pdf.
Old Jul 5, 2005 | 09:18 AM
PDX_Racer's Avatar
PDX_Racer
Generally you can follow these guidelines for what you can change and what you can't:
Consumable - yes for stock
Non-consumable - no for stock
So: air filter, tires, shocks, brake pads, fluids, cat-back -- yes. Intakes, headers, cats -- no.
There are provisions for additional things -- wheels, for instance. Generally they aren't consumable, but the stock wheels aren't always the strongest. Plus, you can argue that tires need something to mount them on. Also, front sway bar changes are permitted to help balance a car.
So, you could do like some people do -- run the mods on the street, but replace them with the stock pieces for competition.
Old Jul 5, 2005 | 09:46 AM
del105's Avatar
del105
15 f125
A pop charger isn't going to do anything for you in terms of performance, mind as well save the money. I bought the HKS air filter because I can hose it off and reuse it rather than replacing a filter.
As for brake pads I'm a really big fan of the carbo tech bobcats. I had a hard time finding the rears and had to order them directly from carbo tech.
I don't if you can improve on the OE pad much as far as Auto-x is concerned.
