Gas tank
Old Aug 11, 2005 | 08:09 AM
mball's Avatar
mball
Default Gas tank
How big is the gas tank in a Z? The book says 20 gallons but, the gas gauge shows differently. I have put gas in my car with the gas light on and it only takes 14 gallons. I am trying to run it as empty as possible for an autocross this weekend. However, I don't want to run out on the way there.
Old Aug 11, 2005 | 08:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
It really is 20 gallons. When my trip computer shows ---- on DTE I still have 3-3.5 gallons left. When I go racing I drive around on ---- for a good 50 miles, then run at the track (1/4) a few times, then drive a few miles to the gas station and I still have only put 18.5 gallons in at most. I guess they make the gas light come on early so people dont ever run out.
Old Aug 11, 2005 | 10:37 AM
Rob Hines's Avatar
Rob Hines
Make sure that you have at least 1/4 tank of fuel in the car. Otherwise, you will suffer some fuel starvation in right hand turns.
-Rob
Old Aug 11, 2005 | 10:52 AM
mball's Avatar
mball
I have not noticed any fuel starvation problems in the 2 years I have been autocrossing the car. I have raced a couple of times with the fuel light on.
Old Aug 11, 2005 | 11:22 AM
PDX_Racer's Avatar
PDX_Racer
Is that is what that little yellow light is for!
I thought it was an indicator that the fuel level was just right for the three fastest runs!
Old Aug 11, 2005 | 11:47 AM
John's Avatar
John
The fuel gauge will adjust the reading level to your current driving, so if you are at the track for a session, it will project how much fuel you have left based on your driving. Once you turn off the car, it resets itself.
For AutoXing, you shouldn't encounter any problems, but with road racing, you may be in a very long turn that has sustained lateral g's...
-Rob
Depends on the track. At VIR, if I have less than 8-8.5 gallons in the tank, I have fuel starvation halfway down the straight as a result of T17(long sustained right hander for those of you who don't know the track).
Old Aug 11, 2005 | 01:14 PM
amolaver's Avatar
amolaver
Originally Posted by John
<SNIP>
Ditto... Any long right hander followed by a straight has caused this for me...
Wonder if I can squeeze an accusump (can they be used for fuel?) somewhere...
ahm
Old Aug 11, 2005 | 02:22 PM
John's Avatar
John
Adam, what left hander have you had problems with? How much fuel did you have at the time?
Old Aug 11, 2005 | 03:05 PM
amolaver's Avatar
amolaver
its right handers - fuel pump/pickup is on passenger (right side). T10 at Summit does it on anything less than 3/8 tank (when the motor is started before a session). The downhill right onto the front straight at lime rock as well - i think the elevation change magnifies the effect. Basically, I try not to get below 1/2 a tank before going out for a session. With my turbo going on, I'm actually pretty concerned about this (going lean + FI ==BOOM), and seriously considering doing something like an accusump (some form of accumulator) to prevent starvation.
ahm
Old Aug 11, 2005 | 06:26 PM
Jason H's Avatar
Jason H
Happens to me down the back straight at MO which has a long right hander (Key Hole) before the straight. Maybe autoXers don't experience it??
Old Aug 11, 2005 | 07:09 PM
PDX_Racer's Avatar
PDX_Racer
It's very rare that autocross courses have long turns, and even more rare that we have long straightaways afterwards.
Old Aug 12, 2005 | 03:32 AM
FritzMan's Avatar
FritzMan
I've done as many as 8 Solo2 run with the light on (all in one day) - no issues. In fact, the car seems to run faster.
20 Gallons eh? That's about 75 liters. The most I've had to fill was for 72. I figured it was a 70 liter tank with a couple of liters going into the filler neck or something.
Old Aug 12, 2005 | 05:16 AM
del105's Avatar
del105
15 f125
I've never gotten fuel starve during an auto-x, Most of the time after an event I fill up 18-19 gallons. I try to get to the event with the trip gauge saying 0 miles to empty.
Old Aug 12, 2005 | 07:17 AM
christoc's Avatar
christoc
I run my car on empty, autocrossed the hell out of it and have never had any starvation issues. The most gas I've ever had to put in the car was 19.3 gallons, twice I've gone that low. At nationals this year I plan on having to put gas in the car between thursday/friday runs.
Old Aug 12, 2005 | 08:20 AM
mpowers's Avatar
mpowers
Thats funny I run a full tank of gas during an autocross, on purpose. Just like the way the car feels with a full tank.
Old Aug 12, 2005 | 08:23 AM
christoc's Avatar
christoc
We're giving up over 200lbs to the RX-8s, so I drop as much weight as I can. Call me silly, and most of you will, but at Nationals I'll be draining my windshield wiper fluid...
Old Aug 12, 2005 | 07:03 PM
enthuzd's Avatar
enthuzd
I've also had fuel pickup issues after turn 10 down the front straight at Brainerd and at Road America after the carousel and kink. I try not to go below a half tank.
Old Aug 12, 2005 | 08:48 PM
PDX_Racer's Avatar
PDX_Racer
Don't forget to drain your xenon light fluid as well...
Old Aug 13, 2005 | 04:33 PM
racin's Avatar
racin
Posted this exact problem over two years ago here:
http://www.ntechengineering.com/inde...n=update092803
Our fix was a major fuel system upgrade/change. We run two pumps, braided stainless lines, and two fuel returns from the fuel pressure regulator we use... No more problems.
Old Aug 16, 2005 | 02:47 PM
dirtroad's Avatar
dirtroad
My 03 is getting progressively worse for this - lately the E light comes on and I only put in 13 gallons or so - used to be about 16. Annoying.
