Your opinions on best alignment specs for track?
I know that there are certain allowed ranges in the 350z recommended alignment specs, but I'm wondering if there is anything to be gained in tweaking alignment (eg changing camber / toe) from stock specs. I'll be taking my car to the track next month.
For those of you who track their Z's, what would your optimal alignment specs be and why? thanks
I am running T2 suspension, 700 lb springs
EVO control arm, Evo sways on med F/R
SA Koni full stiff
Front camber 3.0 deg
Rear camber 2.2 deg
275x40 V710 tires on 17x9 wheels
Well balanced, and can bring out the rear with power
SA Koni full stiff
Rear camber 2.2 deg
In fact, I think they used one of their "ways" to curb my tire feathering. He said Nissan suggests +1.0 degree positive camber to help with feathering. In turn, the outside edges of my tires are worn down, and the inside edges are perfect. My real question is relevant to this thread... How would you adjust camber without using aftermarket hardware?
Originally Posted by Rosko
Please forgive my ignorance. I always thought you couldn't adjust camber on the Z, but I see here that apparently you can (perhaps C RAY Z uses aftermarket hardware) But still, I said as much to a tech at Nissan, and he said something like, "Oh there are ways to adjust camber".
The EVO control Arms is what C ray Z used to adjust his camber.
Originally Posted by Armitage
A bit off-topic, but what are the camber settings for the Z's stock? My Z definitely has a good bit of camber from the factory.
SA Koni full stiff
Rear camber 2.2 deg
SA Koni full stiff
Rear camber 2.2 deg
you have the tire and wheels setup I'm looking into this season. Does the car have crazy turn-in with 3.0 camber? Being that I was running the typical stagger of 245/275 and had my sway bars f/med r/stiff with an alignment of 1.90 front 1/4in toe out and 2.1 rear 1/4 toe in, I was hoping 275s all around with adj front camber arms would cure the understeer (autocross).
