Help - Looking to swap out pumpkin
Question for you experts...
I want to run a 3.9 gear for track events, and I want to save my stock rear end for the top gear, high speed, open road events. I want to be able to just swap out the entire pumpkin instead of having to change the gears every time (a far easier job).
I am looking to save some dough, so I was looking into buying a used (i.e., salvaged) rear end. I know that the Base model cars don't have limited slip, so I am looking for a non-Base model rear end.
There is a salvage dealer in NoCal who wants to sell me the rear end from an automatic. He says that since I want to swap out the gear any way, it doesn't matter if its from a MT or auto. Is this true? He says that the only rear end that his info says is "locked" is the automatic. The used automatic rear end is cheaper than the used MT rear ends - why would this be?
Is there any difference between the automatic rear ends and the MT limited slip rear ends?
Thanks.
Thanks.
Originally Posted by GaryM05
I believe that the 5AT rear end is a 3.3 FD, whereas the 6MT is a 3.5.
What about the REST of the pumpkin/diff? Are they interchangeable?
Originally Posted by knight_white99
Yes, I know that. That's not important, since I will be changing out the stock gear (in either case) with the 3.9 ring and pinion.
I don't know of any other difference besides that, but you could always try visiting your trusty neighborhood Nissan parts department and ask about any part number differences between the various components in the 2 pumpkins.
Good luck with your project.
It all sounds like a good idea.
May I ask what kind of event would require the swap back to the 3.5 unit? Will you be doing speed challenges?
I barely make it to fifth gear with the OEM final drive down the back straight at MidOhio, going ~120mph. I doubt I’d need a seventh gear with a shorter ratio.
Is it really worth it to swap both drives?
SpartanZ32
Oct 22, 2015 09:36 AM
