Need .25" Spacers and Studs for AutoX
Old Mar 3, 2006 | 12:04 PM
l30thelion's Avatar
l30thelion
Default Need .25" Spacers and Studs for AutoX
Where can I get a set of .25" spacers and necessary longer studs?
Old Mar 3, 2006 | 02:34 PM
tomsn16's Avatar
tomsn16
Carter and I use Nissmo 60mm (part#4022-RS045) from performance nissan.Cost about $130 delivered for 20. Don't know of a source for .25" spacers.We had ours made by local machine shop...very expense.
Old Mar 3, 2006 | 03:05 PM
jun14scr's Avatar
jun14scr
some guy in the classifieds is selling a 4mm spacer. had multiple kits for sale.
dose a a 4mm spacer even need a stud replacement?
Old Mar 3, 2006 | 04:55 PM
tomsn16's Avatar
tomsn16
The guideline we use is to have a minimum of one diameter(12mm) of stud available for the lug nut. If you use stock wheels that's about where you will be with 4mm spacers.Suggest you measure to be sure.
Old Mar 4, 2006 | 06:26 PM
christoc's Avatar
christoc
Check some speed shops in your town, I know Wise speed shop here in St. Louis sells spacers for pretty cheap.
Old Mar 4, 2006 | 09:04 PM
daveh's Avatar
daveh
How exact does it have to be to .25"? H&R makes 5mm and eibach makes 10mm spacers (both of which include studs). I'm running both of these on my car. Bought from the good folks at Performance Nissan.
Old Mar 4, 2006 | 09:20 PM
christoc's Avatar
christoc
In BS the offset can't differ by more than +/- .25" from the stock offset.
Old Mar 6, 2006 | 07:20 PM
BA Cutler's Avatar
BA Cutler
I have a set of H&R 5mm spacers. They include a warning about differences in their studs vs. the OEM items. I should've taken their warning seriously.
My experience was I could've purchased my Nismo studs a couple of times over... by realizing the H&R studs are not an exact match (towing charges, tools, etc.). Notice the splining on the H&R studs begin immediately after the head. On the stock studs, the splines do not begin until a mm or two after the head. Effectively, the H&R studs only bite into the hub about half as much as the stock studs do.
Don't do what I did, pull those puppies out and replace them with the Nismo studs.
BC
Old Mar 6, 2006 | 09:04 PM
christoc's Avatar
christoc
I've yet to break a Nismo stud, replaced far too many of the stock studs.
Old Mar 7, 2006 | 07:15 AM
BA Cutler's Avatar
BA Cutler
I don't know why I have to learn every lesson to be learned firsthand! But once I learn them, at least most of them stick.
BC
Old Mar 13, 2006 | 11:03 AM
DmanG281's Avatar
DmanG281
Found some super cheap spacers at www.jegs.com. 50 bucks for a complete set of Baer spacers. They are listed in Standard sizes but they should fit.
Old Mar 13, 2006 | 06:50 PM
03Z33's Avatar
03Z33
Eibach also have spacer/stud kits in stock with the correct hub sizing, etc... and the correct knurl on the studs! H&R does have the wrong knurl, but it works in a pinch...
Old Mar 13, 2006 | 07:32 PM
PDX_Racer's Avatar
PDX_Racer
The Eibach 5mm spacers are only about $65.
Old Mar 14, 2006 | 10:29 AM
BA Cutler's Avatar
BA Cutler
H&Rs 5mm were just under $60
BC
Old Mar 15, 2006 | 07:04 AM
DmanG281's Avatar
DmanG281
the baers are $23 with coupon and they come in 1/4" exact sizes
Old Mar 21, 2006 | 06:40 AM
sq40's Avatar
sq40
Do you have a link directly to those?
I don't have my wheels in yet, but I think I need to make up about 20mm to get the look I want. What would be the best, low cost, solution? Nismo Studs and a low cost spacer?
Old Mar 21, 2006 | 10:37 AM
DmanG281's Avatar
DmanG281
For 20mm I would probably go with a spacer that has the studs on them. but here is the link for the spacers I'm talking about http://www.jegs.com/webapp/wcs/store...tegoryId=58302
Old Mar 21, 2006 | 10:51 AM
sq40's Avatar
sq40
Looks like we have a couple of threads going back and forth on this.. BUt..
.25 Inches is 6.3mm.. From what I understand a 5mm Spacer only leaves your 2 turns left for your lugs.. 6.3 would probably knock that down to 1 turn.. right?
Old Mar 21, 2006 | 11:59 AM
jcarp's Avatar
jcarp
you should just be able to use .25 inch spacer and quarter inch acorn bulge lug nuts and be fine. you can get this from any wheel shop but i'd go hr with longer studs to be safe
Old Mar 21, 2006 | 12:20 PM
sq40's Avatar
sq40
Is Nismo the only game in town for Longer studs?
