BBK with 17 in wheels
Old Jul 12, 2006 | 10:12 AM
uwaeve's Avatar
uwaeve
Not to hijack the thread, but I think this could be helpful and on-topic.
OK, so I'm looking at track (that's track-use, not Track-model) wheels to go over my OEM Brembo setup. Not too many plans to go bigger on the brakes, I bought what I though I needed in the first place.
Pertinent info is this:
Must be non-staggered
Must clear stock Brembos
Must be cheep (<~ $1600)
Must be 9.5" wide to fit the widest tires possible (I see a lot of 17x9.0)
Must have offset to run without spacers.
Light fender work not a problem, I'll roll or cut to get my precious 275 or 285 under there.
Wheels can be cast but can't be junk.
No fanciness like fake rivet heads or polished lip. Don't care what the "dish" looks like.
If I can get a good price on the LMGT4 18x9.5 30mm, they fit the bill (little more expensive) but will cost me an arm and a leg in tires when I start eating the expensive stuff.
I've combed through this thread and the aforementioned 17" wheel thread, and don't see anyone running a 17x9.5" wheel over the stock Brembos or any aftermarket BBK. So is anyone running a 17x9.5" over stock Brembos or aftermarket >13" BBK?
Are the stock Brembo calipers considered "large" in relation to their rotor size? Does anyone have a Stop-Tech-like fitment template for the OEM Brembos?
Thanks in advance for saving me enough money to buy 6 sets of tires where I'd only be able to buy 5 with the LMGT4s.
uwaeve
Old Jul 12, 2006 | 10:19 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
uwaeve
Thats a lot of tires. Are you going to buy them all at once? If so do you have a climate controlled area to store those tires? Why not just make it so you have one set on your car and one set as backup? IMO the Nismos are your best bet. Quality construction, good looks, lightweight, and quality fit with 285/30/18 tires. I myself am looking for a second set of wheels to mount some Hoosiers on for time attack use and can't find anything comprable in 18" x 9.5" +30 so I will probably end up with another set of Nismos.
Old Jul 12, 2006 | 10:53 AM
uwaeve's Avatar
uwaeve
No, not at once! Just looking at the long-term cost of tires. It's like $1100 for 275 18" and $800 for 275 17" in the same tire in some cases, so with the cost difference, I can get more of the 17" tires over time. Like 6 for the price of 5 in my example.
To fill everyone in, 350ZNV has given me a lot of good info on the Nismos, now I'm just looking for options before I jump. If there are no good 17" options that fit all my criteria, then the Nismos are the way to go!
Old Jul 12, 2006 | 12:54 PM
Nano's Avatar
Nano
I run a custom wilwood 355mm setup front/rear with 17 5zigen Fn01r-c
no pictures yet, sorry
Old Jul 12, 2006 | 02:33 PM
sfarrah's Avatar
sfarrah
17x9 +35 5Zigen fn01rc's with 275/40 hoosiers with 3mm spacer and 17x9.5 +38 5Zigen ProRacer GN+ with 274/40 Falken Azenis and 3mm spacer fit over my 13inch Stoptech kit. Ideally I'd use less offset but I use these wheels on my z32 also.
Old Jul 16, 2006 | 07:20 AM
uwaeve's Avatar
uwaeve
Thanks in advance.
uwaeve
Old Jul 16, 2006 | 08:13 PM
cwalker's Avatar
cwalker
I use Enkei RPF1's in 17x9 +35 with a 15mm spacer. Same setup front and rear with 275 V710's.
Light wheel... only 15.9lbs each. Paid around $1200 for the wheels and spacers were around 250ish.
Btw, they clear the Brembo's by about 2-3mm in the front... it's tight, but they fit. No fender-work necessary.
Obadabot
Jun 18, 2023 11:31 PM
