Which sway bars?
Old Dec 7, 2006 | 01:16 PM
05-Z's Avatar
05-Z
Although I don't have it, I'm surprised nobody has mentioned the Hotchkis sway bar/spring combo.
I'll probably order the Hotchkis sways soon.
Old Dec 10, 2006 | 09:18 PM
03performz's Avatar
03performz
That's B.S. what that guy said about the sways. It is car dependent. The Z has tons of understeer from the factory and stiffer sways transform the handling characteristics. I'm running full stiff up front and middle stiff in the rear with Stillen sways. The Z felt loose before. It's much more responsive and predictable now.
Old Dec 14, 2006 | 09:51 AM
cwalker's Avatar
cwalker
Originally Posted by 03Z33
I run the 350 EVO's and didn't realize they are no longer available...
I ran a 350 EVO sway and T2 springs in A/X last season and loved it. Handled really well, really predictable/progressive... and very fast. I personally thought the springs made the largest difference in performance, but too bouncy without the TC Kline DA shocks.
I sold my car, but I still have the 350 EVO front sway if anyone is looking for one.
-Casey
Old Dec 14, 2006 | 11:33 AM
amolaver's Avatar
amolaver
If one wanted to go with the TC Kline DA's and T2 springs/sways, does one just call TC and ask for it as a package, or are there multiple vendors involved. I know with Mazda (for my SM), you have to be a 'member' of the racer program to buy things from them - is Nissan the same way?
ahm
Old Dec 14, 2006 | 12:53 PM
12AutoX's Avatar
12AutoX
I am running Cusco sways front and rear. The front is great, and adjustable (2 settings, I run stiff). The rear is a different story. On the track, on street tires (Falken 615's) corner exit oversteer is a problem. I think the Cusco rear bar is too stiff for the OEM suspension. Maybe it will work better with aftermarket dampers/springs. I am thinking about swapping my OEM rear swaybar back in to see if it helps. I am not the only person to experience this issue, either. Even rolling gently on the throttle coming out of a turn, it is clear that I should be able to put down more power sooner.
Old Dec 14, 2006 | 03:56 PM
daveh's Avatar
daveh
ahm
Yup, just call them up, give them $1600 and install. You could call truechoice also for a slightly different valved and shortened shock too
AutoX, I had the same oversteer problem with stock suspension and evo sways. It's the shocks not the sways..
Old Feb 19, 2007 | 02:59 PM
commasense's Avatar
commasense
FYI, in case you hadn't heard, 350EVO will have their sway bars in again starting next week.
In the meantime, I've gotten myself a set of 17x9.5" track wheels and am planning on buying a set of Toyo's new replacement for the RA-1. So I may hold off on any changes to the suspension until I see how the car performs with 275s all around. (Change one thing at a time, right?)
If anyone would like to buy a set of 350Z Track model alloy wheels, in good (if not perfect) condition, make me an offer. (Tire pressure sensors not included.)
I also have a set of lightly used Hoosiers I got from Jason last summer and never used.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
