Towing car with no front wheel
Old Dec 3, 2006 | 09:23 AM
commasense's Avatar
commasense
Default Towing car with no front wheel
My front left wheel hub broke at the track yesterday. I felt something was wrong and was able to drive off the track, but when I jacked up the car, the whole wheel assembly rocked back and forth.
We winched the car up onto a trailer and got it back home, but rolling it off trailer may have broken some other parts. (Late on Saturday night, I couldn't leave the car at the shop where it will be fixed.)
So I need to get it to the shop without putting any weight on the front left wheel. When I had a wrecker at the track, before deciding to trailer it home, the driver said he couldn't use his hook because it would break the car's plastic nose. I don't think it will be possible to use one of those tow trucks that lift it up by cupping the front wheels, because the left front can't support any weight, and the carrier could do more damage to the underbody. I think that winching onto or off a flatbed could also do more damage.
So what other options are there? In short, how would you transport a car with no front left wheel?
Thanks for your advice.
Old Dec 3, 2006 | 10:51 AM
commasense's Avatar
commasense
Now that I've had a closer look, the part that broke is the hub that actually holds the wheel and brake rotor onto the bearing. The outer portion with the lug bolts just sheared away from the center hub in a nice pentagonal section.
Fortunately, it doesn't look like any other suspension components were damaged, although brake rotor will have to be replaced and the caliper got a little banged up.
But the car still can't roll on the front left wheel. So I may still have to figure a way of getting it to the shop, and answers to the question above are still welcome.
But I'm wondering if I might be able to fix it myself. In the official 350Z service manual (Page FSU-8), they label that whole assembly, including the bearing and the arm it's attached to, as the axle. But they don't show a procedure for replacing the hub (or the bearing) by itself. Does anyone know if it would be easy for me to do it myself without any special tools?
Thanks.
Old Dec 3, 2006 | 03:21 PM
MoodDude's Avatar
MoodDude
I have never replaced a hub bearing, but it should be pretty easy. Try unbolting the hub and go from there.
They sell used hubs on e-bay off of wrecked cars for a really cheap price for 350Z's. Another option to make it a cheaper fix.
Old Dec 3, 2006 | 03:29 PM
Eazzy's Avatar
Eazzy
Ur going to have to use a "suck up" truck ---It has a flat bed that angles down like a ramp then winches the car up, then levels out for transport. U have an Eye bolt with ur jack that scews into the front of the car to attach the winch to. If the guy knows what he is doing , there will be no more damage
Old Dec 3, 2006 | 03:31 PM
Eazzy's Avatar
Eazzy
And a Hub Brging , is a easy fix---IF that is all thats wrong
Old Dec 3, 2006 | 03:40 PM
MoodDude's Avatar
MoodDude
On a side note - when you do replace your hub bearing - could you check with Nissan if there is another car or truck with the same hub. The one on our cars is pretty sloppy, and if a heavier vehicle matches it would probably be stronger.
Old Dec 3, 2006 | 03:46 PM
Eazzy's Avatar
Eazzy
Nissan only knows part #s ---If u get into a beefier hub assy, u would be getting into a larger diameter assy that wouldnt fit and may very well have a different wheel stud spacing.
Old Dec 3, 2006 | 09:34 PM
03Z33's Avatar
03Z33
Would you be able to put a wheel dolly under the wheel so it doesn't have to turn? That way you could get it onto the flatbed.
etkms
Jun 19, 2022 06:30 PM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
sherm
Sep 10, 2015 11:02 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
