stock tire pressure
Old Dec 7, 2006 | 08:36 PM
lbhornbu's Avatar
lbhornbu
Default stock tire pressure
what is a good auto-x tire pressure to run on the stock 17" bridgestones? this will be my first solo2 event w/ the Z, plan on switching to r-comps next season, car is bone stock, only had for a week(never spent more time driving in 7 days than any other week in my life ). any recommendations would be awesome. thanks.
Old Dec 8, 2006 | 06:37 AM
PDX_Racer's Avatar
PDX_Racer
Somewhere in the 40-50 PSI range.
I usually use 44F, 40R, but your pressures may vary.
Old Dec 9, 2006 | 09:58 AM
lbhornbu's Avatar
lbhornbu
thanks, does anyone run w/ other pressures on the stock tires?
Old Dec 9, 2006 | 10:01 AM
skidmarq's Avatar
skidmarq
Those are "hot" PSI readings, correct PDX?
Old Dec 9, 2006 | 11:47 AM
PDX_Racer's Avatar
PDX_Racer
Those are *COLD* PSI readings, for track usage you want "hot" PSI, so start a bit lower than that.
Depending upon when the tires were inflated (ie. how much water vapor is in the air), you probably want to start at 40-42F, 36-38R -- that should give you around 46F/42R hot. Change the pressures as necessary to fine-tune the balance of the car.
Old Dec 9, 2006 | 01:30 PM
skidmarq's Avatar
skidmarq
Cool, thanks for the clarification!
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
