bone stock Z lap times around SOW both directions?
Old Jan 10, 2007 | 07:49 PM
ketsup's Avatar
ketsup
Default bone stock Z lap times around SOW both directions?
i searched but couldn't find anything on how fast a bone stock Z is around streets of willow (sow) in both directions. what kind if laptimes are you guys able to achieve with a bone stock Z? (other than brake pads and fluid changes)
Old Jan 10, 2007 | 08:31 PM
Tekwon-V's Avatar
Tekwon-V
i've done sow once (i was bone stock, even the tires) didnt have the transponder though.
lookie here, you may be able to "guess" and see if some of the 350z's on the list are stock. say... the one listed on there - 2006 350z with "300hp" 1:41:xx
i only have laptimes available from the willow springs, which i will be doing it again end of the month!
Old Jan 11, 2007 | 04:46 PM
WA2GOOD's Avatar
WA2GOOD
I did a back to back test for Sport Compact Car Magazine about a year ago. They put me in (Eagle1's car) a highley modded out built motor JWT TT'ed G35 coupe, and then had me run as fast as I can in a brand new (completely) bone stock '06 G35 coupe for a comparison. Although this was the first time that Eagle1's (Ed Reeser) car had been driven at all since its complete makeover, I did manage to run a lap of 1.25.604 around Streets of Willow's full track with the bowl. I was able to squeeze out a lap time of 1.35.7?? in the bone stock G35 coupe sport. So, there was about a 10 second difference in the two G coupes that day.
I also have alot of track time in 350Z's and I am sure, given that the Z is 200-300 lbs. lighter with a 8" shorter wheel base and always slightly faster than the G35 coupe, that a stock Z is capable of a 1.34.??? to maybe a low to mid 1.35.??? without a problem
--Scott
Old Jan 11, 2007 | 05:12 PM
ketsup's Avatar
ketsup
was that with or without the blowpass?
Old Jan 11, 2007 | 05:41 PM
WA2GOOD's Avatar
WA2GOOD
Not sure... Is the blow pass is what deletes that last couple of kinks before the start/finishline?
If so it was with the blowpass, I average almost exactly 3 seconds slower with the kinks there... Hope that helps..
Old Jan 11, 2007 | 06:37 PM
ketsup's Avatar
ketsup
oh naw not that part. it's a new part they added i believe about a year ago. going cw turn number 4 or 5?
here's the blow pass
http://i4.photobucket.com/albums/y14...3/StreetLg.gif
it's suppose to be 1-2 secs faster
Old Jan 11, 2007 | 07:09 PM
WA2GOOD's Avatar
WA2GOOD
Sounds interesting...
But, nope, I have never ran this "blow by" track configuration, or counter clochwise for that matter. I am sure you would pick up about 2 seconds cutting out that sharp right hand hair-pin turn. The times I was refering to above where full track, clockwise, with the bowl.
Old Jan 12, 2007 | 06:51 AM
mhoward1's Avatar
mhoward1
check www.mylaps.com
You can look at laptimes by cars and venue.
Dr.Paulyy
Jul 29, 2019 07:45 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
