alignment setting for track day recommendation
Old Feb 15, 2007 | 09:43 AM
FritzMan's Avatar
FritzMan
Originally Posted by Fab_vr6
Fritzman, I am brining the Cusco arms to the shop to install next week w/ alignment, what should I ask him to do if I want to have 2 pre-set camber setting?
After the alignment is done (assuming I asked him to set the track setting), what is the instruction on how to adjust it back to street setting? what tools do I need and is it something I can do in my garage with accuracy or do I need the shop to do it for me with the alignment machine?
Thanks
Gary
Gary, the cusco arms only have something like 4 possible adjustments. Imagine four settings with 1 being the least camber (pulled out all the way), and the 4th setting having the most negative camber (pushed in all the way). For the street, I run setting 2 which is -1 with my spring setup, and then for the track I run the 4th setting which is -2.9.
Adjustment is provided by sliding the lower plate along the fixed upper plate. As you move the lower plate you'll notice that at preset increments, different bolt holes will line up to allow you to bolt the two plates together. Study the arms before installing them to see how they work.
To change settings, you simply need a hex key (5mm I think). Make sure there's no grit in the upper plate track otherwise the plates won't be able to slide their full length which prevents the holes from lining up.
The only alignment I'd consider is have the toe adjusted for a specific setting. Personally I did it at max camber for the most predicatabililty when on the track.
Old Feb 18, 2007 | 09:18 AM
Fab_vr6's Avatar
Fab_vr6
Hey FritzMan,
thanks for the tips, I took a close look at the arm yesterday and notice the bolts you mentioned. However, how tight should I tighten those bolts? (I assume it can be dangerous if they come loose when I drive, espically at the track).
Gary
Old Apr 24, 2007 | 10:01 AM
Kolia's Avatar
Kolia
Old topics are the best...
Old May 10, 2007 | 01:01 PM
Chebosto's Avatar
Chebosto
bumpity for question:
how to get more than -2.9 from cusco arms?
i had my alignment from Mworkz last week, my driver side i could only get -2.5 but passenger was a -2.9
i would like to see if i could get at least < -3.0
any of you modify your cusco arms? and how?
Old May 10, 2007 | 09:50 PM
The HACK's Avatar
The HACK
Hey C., this is Dan, Doeboy's friend...Met you a couple of times? When are you going to take that beast of yours out to the track man? John's made instructor you know...
C'mon, if you're not busy, at least come out and get some rides with us this weekend at Buttonwillow or June 2-3rd at Willow Springs. It'll be fun.
Old May 15, 2007 | 08:02 AM
NA&CH's Avatar
NA&CH
Quick question from a track noob
Going from street to track/autox do you need to get it aligned after you switch. I assume no. But say the Autox events are a month apart(first weekend of the month).
Thanks guys and very good read
Chris
Old May 15, 2007 | 08:09 AM
Kolia's Avatar
Kolia
Chris
You don't have to change it back.
But you will get more tire wear if you keep a track alignement.
Old May 15, 2007 | 09:28 AM
NA&CH's Avatar
NA&CH
Thanks Kolia Is there a good thread discussing different track setups with cambers and what not? I am searching.
Old May 15, 2007 | 09:31 AM
Kolia's Avatar
Kolia
Just scroll down the Autocross/Road forum and you'll find some topics.
Remember that front camber is not adjustable on our cars, so we are somewhat limited in alignement options.
Old May 15, 2007 | 09:18 PM
The HACK's Avatar
The HACK
If you're a noob at this auto-cross thing, and the car sees more street time than "track" time, I suggest you leave it at a conservative setting and don't worry about it until you have at least a half dozen events under your belt.
At your current experience level you will not know what to do with "setup" even if it bit you on the @ss. It will only slow you down. Trust me.
Just go, do the events, and eventually the stuff you read here will click and you'll start figuring out things about settings and why the car behaves a certain way when you change a certain setting. Otherwise all you're doing is trying to maximize what you perceive as the car's potential when the biggest bottle-neck is the nut behind the wheel.
Old May 16, 2007 | 09:52 AM
NA&CH's Avatar
NA&CH
Thanks for the insight. I will be starting up in some autox events. The local one is every 1st weekend of he month. I am getting use to my suspension "setup" that I have on the car. I can't wait for the first event.
I just need to get the tire sizing down...
Just for reference:
HKS LS+ coilovers
Cusco Front Aarms
SPC rear camber
Cusco Sways
Track rims for track/autox events. Right now I have standard tire sizes on them. I was thinking 265 all four corners of the Falken 615's.
Sorry for getting off topic.
Old Aug 20, 2007 | 09:37 AM
daveh's Avatar
daveh
Can one of you engineer folks provide a simple chart with conversions from inches to degrees for toe measurements on a 17" wheel?
ie 1/16" = xx degrees
1/8" = xx degrees
Old Aug 20, 2007 | 01:48 PM
dnguyent's Avatar
dnguyent
1/8" = xx degrees
1/16" = 0.211 degrees
1/8" = 0.421 degrees
3/16" = 0.682 degrees
I'm assuming toe is measured like this:
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
SharX59
Sep 30, 2015 10:54 AM
SharX59
Sep 27, 2015 09:23 AM
