Stock calipers + rotors Vs. Track
Old Mar 29, 2007 | 01:14 PM
  #61
Kolia's Avatar
Kolia
Originally Posted by nicolaycastro
Kolia, are you still using stock brembo rotors or did you upgrade to 2 piece or some other kind/brand?
I have 2 piece Stop Tech aero rotors in the front. Plain surface (had to special order them). Still on the OEM rotors rear.
When I changed the rotors, there were little plain surfaced options available on the market. The OEM front Brembo rotors retail at 450$ each at Nissan and you can’t get them anywhere else. So the Stoptech were cheaper at ~600$, plus the replacement outer rotors are 160$ each. It was a simple decision.
I need new rear rotors now and I’m not sure what I’ll get. Maybe slotted 1 piece Brembo, simply because of the price. I try to avoid slots and drilling as much as possible though. Undecided still…
Old Mar 29, 2007 | 01:41 PM
  #62
Axelerate's Avatar
Axelerate
The price of plain Brembo rotors have come down thanks to Centric. They can be had for around $65 a rotor for the fronts and less for the rears.
Old Mar 30, 2007 | 04:34 AM
  #63
mberthia's Avatar
mberthia
ATE Customer Service replied that the shelf life is 2 to 3 years.
I'll check for a date on the can and I think I will still use it. The most recent one will go in the Z, the other in the winter car as it never has had a brake fluid flush.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
