Handling tight curves
Old May 12, 2007 | 07:48 PM
Z'd Up's Avatar
Z'd Up
Default Handling tight curves
It seems like I can enter right turns way harder than left turns. When I try to take a tight left turn hard I can feel the rear getting loose and I have to ease off. I've fish tailed a few times on tight left turns.
Is it just me or is this in general normal?
Old May 12, 2007 | 07:54 PM
PDX_Racer's Avatar
PDX_Racer
Remember with you in the car, the weight bias is on the left side of the car, which means that your left-side tires are basically "pre-loaded" while the right-side tires are "light."
Old May 12, 2007 | 07:55 PM
Originally Posted by Z'd Up
Is it just me
Yes.
Old May 12, 2007 | 08:05 PM
I1DER's Avatar
I1DER
If you are getting loose on left turns rather than right turns, then you are entering the left ones harder not the other way around. I think it's perception.
Old May 12, 2007 | 08:15 PM
first350's Avatar
first350
1) what mods do you have? (suspension stuff...springs, lowered, camber,...)
2) Have you gotten an aligment done?
3) what tires are you running and what pressures?
Old May 13, 2007 | 05:40 PM
Kolia's Avatar
Kolia
In our life as drivers, we make many many more right turns than left...
Think on and off interstate ramps...
You need training, that's all.
Old May 13, 2007 | 06:44 PM
nzpv03's Avatar
nzpv03
lol opposite for me...i stink at right turns
Old May 13, 2007 | 06:47 PM
chriskabobbers's Avatar
chriskabobbers
i love right turns.
Old May 13, 2007 | 06:48 PM
chriskabobbers
i always fish tail on hard lefts ... well .. not always =P
Old May 13, 2007 | 06:51 PM
Accordaleer's Avatar
Accordaleer
I think i usually take right turns slower because we drive on the right side of the road heh that sounds funny, but left turns you usually have more room so you might take them faster knowing you have room. When i used to go cruising with my friend in his 78 trans am, he would never take right turns fast because of the curb, but left turns were amazing haha
Old May 13, 2007 | 09:23 PM
Z'd Up's Avatar
Z'd Up
davidv, I1der and Kolia - Bingo and thanks!
Old May 15, 2007 | 05:55 AM
mhoward1's Avatar
mhoward1
One thing to also remember is you tend to turn in tighter and later on the drive side of the car. So a Left hander you are turning inlater, and sharper than you would a right hander. It's just natural.
Old May 15, 2007 | 06:04 AM
LeMans 05's Avatar
LeMans 05
One other thought. Is this on a track, or on surface roads? Most roads are crowned, so right hand curves are 'on camber' and left hand curves tend to be 'off camber'. Maybe this is what you're experiencing.
I almost put my Z in to a pole once when I was screwing around. I took a hard left curve on a back road that started out on camber, but at the end of the curve, it dropped to off camber right as I was rolling on the throttle in 3rd gear. Tail snapped out on me, but I was thankfully able to save her before I had to write up one of those 'wrecked my Z' threads.
Old May 15, 2007 | 06:13 AM
Sensi09's Avatar
Sensi09
Works Concepts
I get things a bit mixed up now, but on canyon roads, left hand turns use to be my "weak side." Overall I just felt more comfortable taking right hand turns more aggressively. A lot of it, if not all of it was in my head. Since I'm more comfortable with things, I don't even remember exactly if it was my left or right hand turn that was weaker.
350Z_Al
Oct 29, 2020 07:44 PM
