ABS control unit malfunctioning
Old Sep 16, 2007 | 11:58 AM
dnguyent's Avatar
dnguyent
Originally Posted by Billhyco
oh i thought you meant the module was unplugged.
check out a VSS for the problem.
That is what I did. The module is plugged in via the harness. When I unplug the harness, the module and ABS pump no longer gets power or any signal from the ecu and/or speed sensors. The ABS control unit becomes a dummy hub for the master cylinder and all brake lines.
What is a VSS? Vehicle service s.....?
Old Sep 16, 2007 | 05:51 PM
Billhyco's Avatar
Billhyco
vehicle speed sensor
Old Sep 26, 2007 | 09:16 PM
dnguyent's Avatar
dnguyent
Well, just thought I'd write an update. I got the EBCM back from Gavin Curtis of modulemaster.com, and reinstalled the unit. After doing a full flush of the brake system, I turned on the car, and none of the trouble lights went on!!! Whoohooo!!!!
Turn around was 2 days at a cost of just a hair under $200. I'm curious as to what the dealership would have charged me because I sure as hell know they would have recommended a full replacement of the EBCM. Thanks for all those who gave me advice.
-Don
sales@czp
Sep 23, 2019 03:30 PM
May 30, 2017 03:28 PM
dcains
Nov 11, 2015 11:36 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
