TTB here I come!
Old Mar 19, 2008 | 02:50 PM
  #41
sfarrah's Avatar
sfarrah
Originally Posted by Dave 90TT
Not quite.
My base class was TTD. With the turbos, I was re-baseclassed as TTC*. Up a whole class, and 7 points on top of that.
However, that is specific to my car, with it's weight and whp. It will be different for each car. If you are already maxed out as TTA, you will most likely end up in TTS/U/R, the purely hp/weight classes.
Not maxed out in TTA yet. I think I have 15pts to play with so will likely mod the car to maximize it. Thanks for your response. If I ever turbo/motor swap it I will more than likely be bumped up a class though like you said.
Old Mar 20, 2008 | 03:13 AM
  #42
laze1's Avatar
laze1
I run the 5Zigen 17x10 ET 25, and run a 3MM spacer in front w/ 255/40/17 RA1 with no problems..I run the Hotchkis TVS kit...and stock Brembos
Originally Posted by l30thelion
I currently run in NASA HPDE 3 and am hoping to move up to TTC in the next few months (by completing a Competition School). I'm thinking of running R888s (275 all 4 corners) on 17's and was wondering what wheels you guys would recommend.
It looks like some folks on the board are running 5zigens at 17x10 sizes, which I would love, but dont know if there's any offset at which they wont rub anywhere w/ the stock suspension.
I currently use my 275/40/17 V710s on 17x8 wheels for autox, is this setup dangerous for TTC/HPDEs?
What wheel/tire setup are you guys running or would recommend for optimal grip/handling?
Old Mar 31, 2008 | 02:27 PM
  #43
l30thelion's Avatar
l30thelion
Nice, thanks for the info. Do you think a 275/40/17 would fit up front? Maybe with a 17x10 ET 12?
Otherwise I would have to end up w/ 17x9s all around w/ 275/40/17.
Old Mar 31, 2008 | 05:50 PM
  #44
n1cK!'s Avatar
n1cK!
Infiltrator!
Thumbs up yup...
FN01RC's that are 17x9 +15 will fit with 275/40/17's up front. it's the setup i use at the track.
Fixxxercask
Apr 26, 2011 01:51 AM
laze1
May 30, 2008 11:33 AM
Dave 90TT
South West
Feb 28, 2008 06:01 AM
PBLRacing
Apr 29, 2007 02:02 PM
daveh
Nov 29, 2006 07:23 PM
