anyone else think the Z is misplaced in NASA??
Old Jul 11, 2008 | 05:22 AM
Fluid1's Avatar
Fluid1
Originally Posted by yusoslo
Great information. I am consistant with my times compared to the other drivers so I will go and and see how these change things. I constantly struggle with powering out of corners and maintaining grip.
What is a good reccommended tire pressure if I go out next week on the street tires???
What is the defining issue with the VLSD. is it slower in reaction than a clutch lsd? is there a night and day difference in grip?
Lastly I think no one will know I am running 18x8.5 as opposed to 18x8 up front since they are OEM wheels.
and why not the KW's? maybe stance or BC??
Powering out of corners and maintaining grip is the whole deal with our cars. Exit speed is king for the 350.
Running full fuel is most definitely going to help you, for two reasons. One is of course the added weight over the rear tires, helping to keep them planted. Two is that when you run a half tank, there is significant fuel slosh, helping the tail end get loose. Running more/less negative camber in the rear is a delicate science....too little negative camber and your tires aren't planted in turns. Too much and the tires are too angled to put power down. I have found that a full tank and -1.9* camber has worked quite well for me....
If you think you have issues with the tail end, think how I feel..... I have a Base Z that I race. Open differential. Of course, it has taught me throttle modulation, very much so. It also makes me work harder to plant the rear end, and therefore I am able to give better advice because I'm constantly fighting the loss of traction.
If you go out next week on the street tires, I would start with 42 psi in front and rear. Adjust from there, make sure that you watch the wear indicators. Some people use chalk or white paint or whatever, but you can see what's up.
The one device that best helps show you where your camber and pressures need to be is a pyrometer. It is basically a little gun shaped device that checks the temperature of things. Check the inside, middle, and outside temps of the tire. The difference in temps tell you a lot, but I'm sure I'm getting a little ahead of our discussion here.
The VLSD is a viscous unit, and it depends on it's fluid internally. While it is a LSD, it is not a great one. As far as I'm concerned, the best aftermarket LSD that is available for the Z would be the Quaife. It basically has yaw control built in.
As for the rims..... well I know that they are not stock so does everyone else who has read this thread. Being in motorsports as long as I have, even the simple 'cheater mod' like that is frowned upon. The better you do, the more people want to make sure you have the proper, legal equipment. All you have to do is look at the rim and you can tell what size it is.....it says it.
Old Jul 11, 2008 | 07:00 AM
terrasmak's Avatar
plan to buy kumo V710's 285 all around and mount them on two sets of rear touring wheels (03 touring wheels)
Stock 03 wheels are only 8's front and rear , in a later post you mention you were going to run 8.5 rears front and back . Thats not possible with stock wheels unless you get 06 and newer wheels.
Old Jul 11, 2008 | 11:14 AM
Fluid1's Avatar
Fluid1
Sorry, I missed this.
I can't recommend any of those three sir.
I would have to lean towards TC's dual adjustable Konis that are valvematched to whatever spring you want to run...
I could start a whole big stink about shock dynos and everything, but the readers digest version is:
BS, Stance, KW...... all hype. Could have 4 shocks with 4 totally different shock rates. It's really sad. Aftermarket brakes and suspension are VERY money driven.
Old Jul 11, 2008 | 12:14 PM
laze1's Avatar
laze1
Question: Why can't you do that?
Old Jul 11, 2008 | 12:35 PM
Fluid1's Avatar
Fluid1
Because it's against the rules.
laze1, I saw you on the NASA forums today. I'm sure I'll be seeing more of you, I live in charlotte.
Tony (nice to meet you, kinda)
Old Jul 11, 2008 | 01:11 PM
laze1's Avatar
laze1
yepper, i lurck over there...I have just started to run NASA out of Atlanta
Daytona Blue 350Z Grand Touring #53 in TTB
I was wondering about the wheel issues...I know that they fit,,,didn't know about the rules
See you around!
Old Jul 21, 2008 | 12:16 PM
Fluid1's Avatar
Fluid1
Any updates, Mr. 5 o'clock shadow?
Fluid1's Avatar
Fluid1
See you around!
I'll be in TTC. Hope to see you out racing later this year!
Old Jul 22, 2008 | 05:13 AM
yusoslo's Avatar
yusoslo
haha, well I have my 350evo sways in now med/med, I have the sub box out, got an alignment done, and have 285 slicks now (but not mounted) since ups lost my volks my only wheels are my oem's.
So this will give me a chance to run the car on its current setup but still on street tires.
any major benifits of messing with the oem strut bar? I
actually cranked mine down so it doesnt hit the hood since I have a intake spacer. which kind of pulls the strut tower together. I think?
Old Jul 22, 2008 | 05:46 AM
davids's Avatar
davids
F U StuLax18
A lot of it has to do with the driver, the car will only give you so much of an advantage.
I beat a bunch of s2000's this weekend and I was only running street tires as well. The one car that beat me was an S2000 with slicks.
Most of the other cars I beat all had slicks as well.
B Stock cars should be generally faster than equally equiped lower-class cars.
Thus why PAX timing comes in to adjust the times. Most of the time differences are because of driver skill.
B Esquire
Sep 24, 2015 07:52 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
mansier
Apr 29, 2004 04:25 AM
