Getting prepped for next year, suspension changes, tires etc. Help?!?!
Old Dec 2, 2008 | 08:56 PM
  #41
ke0ki2k's Avatar
ke0ki2k
Originally Posted by idrive_MD
also any reason why you havent considered the BC coilover kit? its very complete and you can choose your spring rates at purchase, cheap rebuild cost and will allow you to achieve the ride height you want (as most coilovers will). I think they come standard with 10/8 rates the rates are changeable in increments of 2-kg...just something I would consider.
after reading/listening to the stuff on the thread I started I wouldnt trust BC or Stance until I saw shock dynos. theyre cheap but you can revalve some shocks that are proven, and you can choose the springs you want on those too, custom race springs arent that expensive really.
just for reference I think anything from a +20 to a +30 offset, depending on camber and drop, will allow you to run at least 285s up front, maybe 295 hoosiers though it'll be a tighter fit as theyre a bit taller. anything higher than a +30 offset up front and you WILL be into the control arm...with 285/30-18 V710s at least.
ablaine
Nov 29, 2016 10:13 AM
Mattg350z
Oct 2, 2015 06:51 AM
Tochigi_236
Sep 27, 2015 03:40 PM
