need wheel suggestion
Old Jan 7, 2009 | 02:46 PM
Ataru074's Avatar
Ataru074
Default need wheel suggestion
do the enkei rpf1 17*10 +18 all around fit over the brembo caliper? and 275/40R17 are fine with those wheels? (I mean... no rubbing, no clearance issues) my camber is -2.5/-2.7 front and -2 rear...
Old Jan 7, 2009 | 03:23 PM
scotts300's Avatar
scotts300
They clear the Brembos. It'll be tight in the front at the fender, but with your camber, should be ok. The rears are no problem.
Here is my 17x10 +25 set-up with 275/40/17 Hoosiers.
I put a baby 3mm spacer in the front because the wheel was very close to the arm, but then it rubbed slightly. My camber is only ~-2 though.
Old Jan 7, 2009 | 03:32 PM
Ataru074's Avatar
Ataru074
thanks!
how do you like running on 17" ? on 18" I have some problem braking when it's really bumpy...
Old Jan 7, 2009 | 09:37 PM
scotts300's Avatar
scotts300
thanks!
I've always run 17" track tires, unless it's raining. Then I run stockers. I like the 17s.
Old Jan 8, 2009 | 08:23 AM
dkmura's Avatar
dkmura
General & DIY Moderator
BTW- Scotts300 is not running RPF-1s in the picture.
Old Jan 8, 2009 | 09:22 AM
scotts300's Avatar
scotts300
Correct. I am running a similarly-sized set of 17x10 FN01R-Cs with big ole' Hoosiers.
Old Jan 8, 2009 | 10:01 AM
Ataru074's Avatar
Ataru074
yep... the enkei will be 7mm further outside.. I need to borrow a couple of spacers to test.
