Power Steering Fluid Capacity?
Old Mar 2, 2009 | 01:08 AM
halfrice's Avatar
halfrice
Default Power Steering Fluid Capacity?
Upgrading to the nismo power steering cooler and using redline fluids, was wondering how much fluid was needed to do a full flush? Thanks
Old Mar 2, 2009 | 09:02 AM
terrasmak's Avatar
Just shy of a quart
Old Mar 2, 2009 | 11:25 AM
laze1's Avatar
laze1
Note: the Nismo cooler may require a little more fluid than the stock cooler (or no cooler at all)
So get at least 2 qts...if not 3 qts to do the flushing procedure.
Old Mar 2, 2009 | 09:17 PM
mthreat's Avatar
mthreat
I recently replaced my PS fluid after an engine rebuild and it took about 1.5 of the containers that nissan sells at the parts counter. I don't know what size they are but they are certainly not quarts (they're maybe 1/3 to 1/2 a quart). In any case, buy two of those Nissan containers and you should be good.
Old Mar 3, 2009 | 01:03 AM
terrasmak's Avatar
I've installed 4 so far, you don't need more than 1. BTW the Nismo one is a joke, you can get the same thing for $30 thru summit or jegs and neither is really good enough for heavy track use.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
