Trying something new...
Old Mar 2, 2009 | 07:30 PM
Davidb's Avatar
Davidb
Default Trying something new...
Well me and my codriver have been debating what tire size to go with for this years autox season. The car is a 03 enth. Last year we ran 275's on all four corners. This year we are going to try a different set up. We are going to stick with the 275's in the front but we have decided to bigger in the rear. I know we will not have much more, if any, contact patch then the 275's but it is a taller tire. So the extra 1.5-2mph will be nice, every little bit helps...right? Anyways the 275's on the front wheels (7.5in) look the same as the 295's on the rear wheels(8in) except they are taller. And for reference the 275 v710's measured out to be a 285 off the wheel and the 295 measured out to be 305 off the wheel. Here are the pictures.
Old Mar 2, 2009 | 09:42 PM
Ruff Z's Avatar
Ruff Z
Dang that's huge! Good luck with that. I'll be running 285/30/18 on all four corners. You're installer have any probs getting those mounted?! And were you seriously having problems hitting the rev limiter in second gear? (Wait I take that back, I take for granted the revup redline)
Old Mar 3, 2009 | 03:56 AM
Davidb's Avatar
Davidb
Well they went on pretty easy...better then what I expected...but I was the installer.
And yeah we hit the rev limiter in 2nd....a lot last year
Old Mar 3, 2009 | 07:07 AM
ke0ki2k's Avatar
ke0ki2k
Looks good. I had problems hitting the redline quite a bit last year as well and i'm on 285/30's with a revup engine :/
no more of that though, switched classes good luck this year!
Old Mar 3, 2009 | 04:34 PM
DriveI65's Avatar
DriveI65
Since when is a go-kart a class?
Old Mar 3, 2009 | 05:32 PM
BPRacer's Avatar
BPRacer
Traitor....
Old Mar 4, 2009 | 07:42 PM
ke0ki2k's Avatar
ke0ki2k
faster and cheaper than ya'll!
lol i'll still be running the Z, ive got alot of V710 left. I'm wanting to get back into kart racing. sprints at black hills circuit, bakers creek, and new castle indiana if the market chills out and I can afford it.
Old Jul 1, 2009 | 11:45 AM
Ruff Z's Avatar
Ruff Z
What's the secret to getting these mounted, since you were the installer? The guy mounting mine is having problems with mine right now.
Old Jul 1, 2009 | 01:09 PM
scotts300's Avatar
scotts300
Those are big effing tires are tiny wheels. I love how autocrossing breaks the mold. My question, however, is will you be able to generate enough heat to get the larger surface up to operating temperature? My 275/40/17 V710s barely get up to temp in the cooler months.
Old Jul 1, 2009 | 02:00 PM
guitarist's Avatar
guitarist
In the cool there wasn't a ton of heat, but we also didn't feel like there was a lack of grip.
Since things have heated up, there's almost too much grip, especially on good concrete (i.e. Blytheville); getting the car rotated was tough even at full stiff in the rear. We've had to play with the setup a bit since then, but I think we have it close to right now.
As for how they got mounted: I wasn't there for the 295s, but I've seen him do it before. The key is lots of lube. Very little brute force is required.
Old Jul 1, 2009 | 04:32 PM
Davidb's Avatar
Davidb
I'm the one that mounted them....I guess a good technique and lots of lube is the key. I work at a lexus dealership in a small state so we don't have the best tire machine out there. I mounted the 275/295 combo in ~10min....
Old Jul 1, 2009 | 05:27 PM
Ruff Z's Avatar
Ruff Z
I guess the problem he is having is getting the bead to set. He can get the tire mounted over the rim, just can't set the bead.
Old Jul 1, 2009 | 08:14 PM
guitarist's Avatar
guitarist
I've heard another local guy (owns his own shop, very good wrench) say the same thing specifically about big tires for the Z.
David has never had a problem with it from what I've seen, and he's using very standard commercial tire mounting tools and compressed air. Nothing out of the ordinary.
I'm thinking the large quantity of lube inside and out helps this process too, as that is the only real discernible difference between how he does it versus others I've seen.
Old Jul 2, 2009 | 07:40 PM
Davidb's Avatar
Davidb
LUBE LUBE and more LUBE. I mean put it everywhere. Work the bead with the tire iron...I guess its all technique.
I fight more on sc430 runflat tires...lol...
ctwentytwo
Feb 27, 2009 02:34 AM
SammySJ99
Northern California
45
Mar 10, 2008 08:21 PM
