Can somebody 'splain this to me...
Old Jan 22, 2010 | 04:26 PM
  #41
Zazz93's Avatar
Zazz93
Gotcha, I miss-understood you previously. But good point about the Miata, with enough grip and Hp's a Miata can out run anything. Jk
Old Jan 22, 2010 | 06:59 PM
  #42
Ruff Z's Avatar
Ruff Z
It's all good
I just hope the Genesis adds another great auto-x car to the mix, doesn't eat tires too quickly, and doesn't utterly dominate GS, spec auto-x classes get boring, this isn't road racing
Old Jan 22, 2010 | 08:20 PM
  #43
PDX_Racer's Avatar
PDX_Racer
At one trip to Willow Springs, a Rhys Millen driven V-6 Coupe ran similar times to the Double Down 370z on the same day. For reference they both recorded 1:37's and looked similar in the amount of prep/mods done, Tires, coilovers, exhaust and intakes, brakes. Notiably, I think the Genesis had Stoptechs and the DD 370z didn't, vice versa on the exhausts. (Same Genesis pictured above).
The G Stock Genesis (the one all of the autocrossers are talking about) is the turbo 4-cylinder.
If I recall correctly, the V6 Genesis is in F Stock.
Old Jan 22, 2010 | 09:33 PM
  #44
Ruff Z's Avatar
Ruff Z
That is correct
Old Jan 23, 2010 | 10:20 AM
  #45
Zazz93's Avatar
Zazz93
I think the little four might be a little underpowered in stock trim. I think this car needs a little mod'ing before its useful potential is reached. But like the OP said if a establish driver has found it fast enough to switch there has to be something to it.
Old Jan 23, 2010 | 04:30 PM
  #46
DavesZ#3's Avatar
DavesZ#3
BTW - the Camber Bolt kit got shot down for the Stock class in the Fastrack released today...
Stock: per the SAC, the “trunk kit” alignment bolts for the Hyundai Genesis R-spec are not legal for use in the Stock category, as they do not meet the requirements of 13.0. The submitted letter states that the part is for “off-highway use”, which does not comply with section 3.8.A of the Solo rules, requiring that all manufacturer’s documentation must be for non-competition purposes. Documentation for non-competition use from the factory service manual or a service bulletin would be required in order to make the part legal for use in the Stock category as a standard part. (ref. 09-716)
http://www.scca.com/documents/Fastra...k-feb-solo.pdf
Old Jan 24, 2010 | 08:45 PM
  #47
Ruff Z's Avatar
Ruff Z
Originally Posted by Ruff Z
It's all good
Since they shot down the bolts, I think my prediction will be spot on! So hopefully there will be a handful of cars that can get it done in GS!
Old Jan 25, 2010 | 02:14 PM
  #48
guitarist's Avatar
guitarist
I think you're right, though I'm interested to see how the R-Spec does in STX.
Old Jan 25, 2010 | 04:28 PM
  #49
Ruff Z's Avatar
Ruff Z
If it's classed in STX, I think it will match up well against an RX8. That is after somebody gets some quality struts and coilovers, camber plates, and a tune with premium gas to get some power out of it!
AbyteZero
Sep 22, 2015 09:17 AM
lgbdog1
Apr 2, 2004 10:31 PM
AadosX
Mar 5, 2004 06:13 AM
