First timer... autocross over road racing?
#41
on
I'll have to find a schedule for those places.
#42
on
The Z is a brute in stock form... in a good way. In autoX you will experience a ton of understeer due to the tight nature of the sport along with the Z's comfort/everyday road use roll and skinny front tires. Just keep this in mind, look far ahead, know the course and really try to round out your turns to avoid understeer/slipping.
As for hitting a road course, don't go road racing (door to door)... just do some lapping days or time attacks to get comfortable. Drive at 80-90%, don't try to kill. Road courses > autoX. Way more track time and lots more speed but your brakes/tires will suffer more.
One thing I do with my stock Z is run a thick oil: 15W-50 Mobil1, it is better suited for the high heat/RPM of autoX and track days. Just make sure when driving your car on a day to day basis you give it lots of time to warm up before beating on.
#43
on
Autocross is good if you have very novice driving skills. Otherwise, it will just set you up with bad habits to break once you start doing HPDEs.
I think Auto-Xs are not worth the time.
#44
The biggest thing I've had to overcome is learning when it is worthwhile to go slower while shortening a track to produce a faster lap.
#46
I can understand you thinking that Auto-X isn't the worth the time. To each his own.
I don't have any experience with HPDE so maybe good Auto-X skills are bad habits on the track. I don't know.
As for your first assertion, I really don't know what the heck you are talking about. Auto-X is it's own motorsport. Have you actually seen good Auto-X drivers in action? Have you ridden with them? Even more important, have you ever tried to beat them on a course in an equivalent car?
#47
on
BUT on a typical autoX course the Z is more a heavy goat prone to understeer and overpower the rear end if you aren't accurate enough...
on a regular track is a momentum car...
two completely different driving style... it's pretty much the difference you have trying to do a donut on the ground around a cone or doing a really wider donut around a skidpad... the feel of the car sliding is the same, but the "challenge" of doing it is a completely DIFFERENT (not easier, not harder), just different beast.
just because I like to repeat myself... autoX is competition... HPDE is learning.
autoX, in the long run, you learn how to "fine" control a car on a tight highway ramp... after several HPDE you gain confidence for any possible LEGAL speed on the road and some.
what matters at the beginning and intermediate and advanced level is how much time you spend driving close to your limit and the car limit...
autoX you just don't do enough.
and a simple fact... get a guy with 3 or 4 years of HPDE experience and put him on an autoX course...
and get a guy with 3 or 4 years of autoX experience and put him on a real track...
let's see who's going to be the most "stressed" at the end of the day.
#48
Ask Randy Pobst, Jeff Altenburg, Scotty White, Cindi Lux, or any other of a VERY LONG LIST of professional race car drivers about the benefits of learning driving skills on an autocross course. Ask any of my past race driving instructors about whether autocross skills are important.
If you can control a spin at 20 MPH, you can control one at 120 MPH. The physics are the same (just the speeds are different). You need faster reflexes at 120 MPH, but everything else is the same. In fact, if you can feel a spin at 20 MPH, you'll probably catch that 120 MPH loss of traction before it becomes an issue. In fact, for road racing it's rare that you'll ever be at 100% of the car and driver -- yet for autocross every run is effectively a qualifying lap.
#52
Well, to me the key word here is TIME!!!!!
I'm sure it is true that autox skills have value. My issue with it is the amount of time spent waiting/chasing cones/waiting some more.......and finally getting to do maybe 5 runs, each of which last less than 60 seconds.
Having a busy job, family committments etc etc, it just doesn't seem a worthwhile investment of my time to spend a whole day in return for 5 mins. of actual "seat" time.
So to that extent, I would agree with the above statement.
#53
If you think that driving is over when you cross the finish lights, here's your wakeup call.
I generally spend between two and four minutes after each run going over data, reviewing what I did right or wrong. That's in addition to putting tire blankets on, or spraying down the tires (depending upon whether they are cold or hot), and opening the hood to get the hot air from around the engine out of the engine compartment.
Then, and only then, do I really have time to visit with and watch other drivers.
I generally attend autocross events where the cars are 'split' into a morning half and an afternoon half, so I'm there only half a day -- but I also volunteer to help run the event as well, so I get to stick around and visit and watch some more.
When I'm doing an HPDE, it's rare that I get time away from my car between sessions to visit with other drivers -- and they're as busy as I am anyway.
When I'm driving "for real" I have virtually no time away from my car -- even if I have someone helping me (which is pretty much required for racing).
350Z_Al
10-29-2020 07:44 PM
