Share your Track alignment setting.
Old 05-12-2016, 04:37 AM
  #61
03threefiftyz
03threefiftyz's Avatar
Track car...light 3000lbs with me in it and packed with fuel, aero and lots of spring.
Front:
-3.6 / 0 Toe to very slight toe out.
Rear:
-2.5 / 0 Toe
Ivan13 (05-30-2019)
Old 05-18-2016, 12:14 AM
  #62
HRMoneyPit
HRMoneyPit's Avatar
I need some camber arms upfront but can't pay 700 for the SPL ones. Seems they are the only one this forum trust on track.
After raising my car and obviously loosing the front camber I used to have it can feel the loss of grip and my tire ware shows me outside tire wear also to agree with my theory
Old 05-18-2016, 01:15 AM
  #63
armt350z
armt350z's Avatar
I and several others are using the modified Kinetix arms. Cheap and effective.
Old 05-18-2016, 07:00 AM
  #64
HRMoneyPit
HRMoneyPit's Avatar
I've read of people modifying them before. Guess I'd need a set in my hands to make more sense
You guys are cutting them to go more negative?
Old 05-18-2016, 07:55 AM
  #65
armt350z
armt350z's Avatar
Yeah, there is a piece you cut off with a hack saw or angle grinder to get an extra degree or more out of them.
Here was mine when I modded it. The top arm is uncut the bottom is cut and the threads show how many additional turns were gained. All said and done, it got me to -3.2 in the front.
Old 05-18-2016, 08:25 AM
  #66
HRMoneyPit
HRMoneyPit's Avatar
Is the same possible with Z1 arms?
Old 05-18-2016, 10:48 AM
  #67
armt350z
armt350z's Avatar
I've never had a set in my hand, but they list as being able to go to -3.5 when using the race spherical bearings. So you may not need to. there does however look to be a couple millimeters you could shave.
Old 05-18-2016, 11:10 AM
  #68
HRMoneyPit
HRMoneyPit's Avatar
I'd likely go with Z1 cause they are stand up and stand behind all their products. I can't take the pain of $700 for SPL ones
Old 05-18-2016, 11:40 AM
  #69
armt350z
armt350z's Avatar
I may swap out my kinetix for the Z1's... the caster adjustment would be nice
Old 05-21-2016, 07:07 AM
  #70
HRMoneyPit
HRMoneyPit's Avatar
I'm hear wanting a better alignment cause the car pulls on the road. But if I am going to get it aligned I might as well wait till I have my front camber arms. While I'm doing that I might as well spend a couple hundred more for the rear toe arms since km running a true set up now.
Problem with this is I was saving for a full clutch kit. Hummmmmmm
Old 05-21-2016, 08:32 AM
  #71
armt350z
armt350z's Avatar
living up to your username I see.
Old 05-21-2016, 09:32 AM
  #72
HRMoneyPit
HRMoneyPit's Avatar
dont remind me lol street cars are so much easier. Wheels, drop and exhaust to sound cool.....track cars are never ending
Old 06-20-2016, 06:30 AM
  #73
HRMoneyPit
HRMoneyPit's Avatar
Got a new job where I have an alignment rack again
So got my Z1 arms in and was able to do my front end alignment
Set the front to
-3.2 camber
-0.12 toe which is 1/8th of a inch out
My rear toe arms and eccentric bolt deletes will be here later today along with my sway bar end links
Planning to set the rear to -2.5 ish to help out power down
And 0.12 toe in the rear
Which should be an 8th of a inch toe in on the rear
Old 06-25-2016, 09:10 PM
  #74
HRMoneyPit
HRMoneyPit's Avatar
Changed up some stuff and settled at this. Lets see my tire wear after a couple more track days
20160623_182256 by Malachi Rosales, on Flickr
Old 06-26-2016, 01:07 AM
  #75
GodISmE
GodISmE's Avatar
What do you guys recommend for a first track day in a stock car (original 18 in reinforced Rays with 22mm spacers all around, P zero 225/245 tires).
Old 06-26-2016, 04:45 AM
  #76
HRMoneyPit
HRMoneyPit's Avatar
Remove the spacers first of all
Old 06-26-2016, 09:32 AM
  #77
GodISmE
GodISmE's Avatar
Either give a reason why or don't reply at all dude. They are not on yet anyway.
Old 06-26-2016, 10:25 AM
  #78
HRMoneyPit
HRMoneyPit's Avatar
Lol
You asked but get your panties all tight when I give advice smh
Old 06-26-2016, 11:27 AM
  #79
GodISmE
GodISmE's Avatar
That's not advice you donkey. It's a smartass'es comment without anything to back it up. ****in useless. Not bothered with all those horror stories about wheel spacers on tracks. Rubbish most if it.
Old 06-26-2016, 11:41 AM
  #80
HRMoneyPit
HRMoneyPit's Avatar
Keep on digging bruh. I'll send you the shovel
Quick Reply: Share your Track alignment setting.
