How much camber without camber kit?
Old Mar 24, 2010 | 10:15 AM
LeManz33's Avatar
LeManz33
Default How much camber without camber kit?
I was wondering how much camber I can get out without getting the camber kit? My Z is lowered on swift springs, I don't have time to buy the camber kit before the event, but need to get it re-aligned.
Just wanted to know how much I can get for now?
Also what would you recommend as far as somewhat of a road race alignment but on stock Z....
Sorry if this is a noob question, I'm coming from an evo, and it stock form you could get -2.5 front and -1.8 rear 0 toe all around without any modifications
Old Mar 24, 2010 | 10:18 AM
jtabraham's Avatar
jtabraham
it really depends on the car and the alignment shop. I'm lowered on tanabe gf210's and the shop I went to couldn't not get it back within spec. Others with the same setup, have had no issue getting back into spec though (without camber kits).
Old Mar 24, 2010 | 10:21 AM
terrasmak's Avatar
You should have plenty of camber, about -2.2 rear but your problem will probably be toe. You may not be able to get into toe specs.
Old Mar 24, 2010 | 12:16 PM
LeManz33's Avatar
LeManz33
Alright, thanks for the response. Anyways I will try to get somewhat of a decent alignment before Time Attack and once I come back I will look into the camber kit
Old Mar 24, 2010 | 05:02 PM
CORNELL's Avatar
CORNELL
it depends on how low the springs dropped it. 1" drop in front will only give you almost -2 degrees camber, you will have to go lower for more or get arms. i lowered mine about 1.5" in front which put me at negative -2.2 degrees in the front i used arms to get -2 in the rear, so i will probably get front arms to go more negative
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
