SCCA auto X questions..
Old Jul 11, 2010 | 10:26 AM
OWTKAST cpt's Avatar
OWTKAST cpt
So would If I'm going to buy tires would a 255 str setup be better for competitiveness or r comps for for bsp??
I'm leaning the STR route
Old Jul 11, 2010 | 10:41 AM
03threefiftyz's Avatar
03threefiftyz
^you need to make sure you follow the rules for wheel width as well.
Old Jul 11, 2010 | 10:51 AM
OWTKAST cpt
8.5x17
A good offset and some 255's
Old Jul 11, 2010 | 10:54 AM
Z1NONLY's Avatar
Z1NONLY
Originally Posted by OWTKAST cpt
8.5x17
I have not seen a good set of 255/45 17's and the 255/40's are crazy small (short) for rear tires.
Old Jul 11, 2010 | 11:26 AM
OWTKAST cpt
I was thinking a 50-55
Old Jul 11, 2010 | 12:56 PM
guitarist's Avatar
guitarist
They aren't that short--still hit 58 in second in an '03 w/6,500rpm rev limit. That's about 2-3 mph off stock height. And less sidewall is your friend, imo.
The car will be more competitive for less money in STR than in BSP. On smaller, tighter courses the Z actually does well thanks to its good low-end torque. The other cars (S2K, MX-5) are continually shifting back and forth between first and second, while the Z can usually just pull second the whole time.
btw, OWTCAST, PM me if you're interested in a set of 17x8.5 +35 SSR Type C RS in Anthracite. <17lbs each, and look almost new.
Old Jul 11, 2010 | 01:12 PM
OWTKAST cpt
I'm unemployed for about another month and half (no not funemloyed lol guy ripped me for spending government money and buying car parts lol.. I was like no not me)
I would think I'd want more offset though with only bring 8.5
Like a 15 or lower???
Also read 2wd was allowed a 9" wheel..??
Old Jul 12, 2010 | 08:37 AM
guitarist's Avatar
guitarist
STR is only 2wd (only RWD, on the allowed cars list, in fact). And yes, the 9" wheel is allowed. I just went with these because I got a decent deal on them, and they are light yet strong.
As for more offset, I don't really know why you'd want more aside from aesthetics. The car is already wide enough as it is, and if you kick in the camber you're going to need to be fast on street tires, the +35s will stick out of the wheel wells at the bottom anyway (they do on my car). Adding to that just makes it that much harder to slalom at the speeds you'll need to to keep up with the narrower S2Ks and MX-5s.
Anyway, let me know. I won't be able to put the car back to stock until mid-August anyway.
Old Jul 12, 2010 | 11:25 AM
OWTKAST cpt
Okie dokie...
I am allowed 255 9.0
Now... what would be good for sidewall on a Z??
Also is there much in term of getting more RPM out of the stock motor with a tune?
Old Jul 12, 2010 | 02:02 PM
betamotorsports's Avatar
betamotorsports
OK, if you're going to run in the ST category you have four tires to choose from if you want to be even remotely competitive:
Direzza Sport Z1 Star Spec
Hankook Ventus RS3
Kumho Ecsta XS
Yokohama ADVAN Neova AD08
Your size choices are basically:
255/40-17
255/35-18
255/40-18
IMHO, the 255/40-17 and the 255/35-18 are the two sizes worth looking at.
Old Jul 12, 2010 | 02:19 PM
03threefiftyz
Originally Posted by betamotorsports
OK, if you're going to sun in the ST category you have four tires to choose from if you want to be even remotely competitive:
Hankook Ventus RS3
Kumho Ecsta XS
255/40-17
255/35-18
255/40-18
+1 on the quoted.
Old Jul 12, 2010 | 03:06 PM
OWTKAST cpt
Which is goin to give me a greater roll out?? A couple locals say they are losing on the high end of 2nd gear to the s2000's
I assume the 18 40
Old Jul 12, 2010 | 03:11 PM
betamotorsports
Just calculate the tire OD from the size information.
Old Jul 12, 2010 | 03:27 PM
OWTKAST cpt
Is there anything considered the "best" tire of are those four a good toss up?
Thanks again to everyone for the input. All the info and "Arguing" in other areas is fairly overwhelming..
PS very hard to find those tires in the right size.... lol
Old Jul 12, 2010 | 03:36 PM
betamotorsports
There is no "best." Each tire has its own strengths. The Dunlop heats up quickest and is fastest in the early runs. The Kumho is slower to heat up but can handle heat better. The Hankook has the best grip but the steering response is vague. The Yokohama handles heat the best and is consistent but generally slower then the others.
FYI... the time differences are very slight.
Old Jul 12, 2010 | 03:44 PM
OWTKAST cpt
Alright... so ... I need to find a wheel offset Ideal for the Z.. that clears brembos (would like to pick some up) In the above tire choices... hmmm I ve got some searching, learning, saving to do lol
Thanks guys.
Old Jul 12, 2010 | 04:25 PM
guitarist's Avatar
guitarist
Thanks guys.
Whatever you gain by going to a taller sidewall in terms of 2nd gear mph will be lost (or more than lost) in decreased feel (taller sidewall=more flex) and low-speed acceleration (from the taller gearing).
Personally, I'd say learn to shift up to third and back down if you're on high-speed courses that much. It's not really that tough, and it's easier than shifting down to first like the S2Ks and Miatas have to do sometimes.
Or you could always raise the rev limiter and spin the engine another 500-800rpms for a few more mph. A bit risky, but it's legal.
Old Jul 13, 2010 | 06:49 AM
  #38
Clam's Avatar
Clam
True, I've only autocrossed with the Dunlop Star Specs and AD08's on two different vehicles, a 350Z and an RSX. However, in terms of heat, the Star Specs hold heat better than the AD08's in hot Texas weather. In terms of heat up, the AD08's heat up quicker than the Star Specs. For consistency and steering feel, the AD08's feel better than the Star Specs.
If I were to have two sets of tires for the seasons, I would use:
AD08: spring/winter
Star Specs: summer/fall
You can't go wrong with either tire though. Set-up is key in extracting the most potential out of any of the top tires
Old Jul 13, 2010 | 02:59 PM
  #39
gunluvS14's Avatar
gunluvS14
-Im street tires with coilovers, intake, and sways.. what in the heck class am I in??? LOL They were all confused.. and causing me more confusion.
IIRC 275 size won't allow you to run in STR, so you are stuck with STU class. If you don't care about being competitive, you can run the stock class or street prepare class as well
- Im running invo 245/275 on RPF1's
Not the best choice for autoX, look into Bstone RE11 or Dunlop Z1 star spec for car weight more than 3000lbs
-Car udnersteered then immediately snapped loose.... Where should set up the sways??? Seems I need to soften the rear???
Understeer in entrance? mid corner? Obviously you are not understeering on the exit, but it sounds like it can be adjust by driving style. It's difficult to give you a definitive answer
-Air pressure?? whats best for the street tires??
Different car setup, different driver, different track condition. When I ran my G35 in STX class with non stagger 245 size Dunlop Z1; I feel comfortable with 33.5psi hot (front) 35psi hot (rear) on asphalt; 36psi hot all the way around on concrete. Car is near bone stock.
-Rev limiter???? course was sooooo tight I was having a touch time on the 1 or 2 decisions.
You can't go wrong with 2nd gear in most tight course, you have enough torque to drive you out. Most shifting mess up balance and waste time.
Hope that helps
Old Jul 13, 2010 | 03:12 PM
  #40
OWTKAST cpt
THAT HELPED A TON.. lol
I am shooting to change my wheel/tire setup to be STR legal
Thank you.. the more i read the more I like what i heard on the dunlops
Car understeered literally til i used the throttle to bring it around... I tried to run it easy and drive it in smooth and lost 2 seconds. I was sliding the rear just to get it to rotate on the tight corners.
Do you recommend more rear then front?? Or is this all just circumstantial I assume??
I never tried just running second gear... if I am ever on a course that tight again I definitely will
