Wanted to share this with the track guys...
Old Oct 23, 2010 | 06:20 AM
rwm10's Avatar
rwm10
Originally Posted by Flo-ridaZ33
Modified Mag installed one on their project S2k and gave a brief explanation on how it works and how to install it.
Yep, I've read that, it was a really good article. I was just curious to where he mounted it in the Z, and what size (1, 2 or 3 quart). I was planning on just the 1 quart, as I don't know how much extra oil can be in the system before it becomes an issue.
GrandAm350, any further info/advice you can offer would be much appreciated.
Sorry for the little bit of thread jacking.
Old Oct 23, 2010 | 02:34 PM
laze1's Avatar
laze1
I have not installed the Accusump in the new race car yet...but will over the winter. Most likely the Accusump will go way back into the rear hatch area with the Diff Cooler plumbing...mainly to keep the heat away from the driver.
Note: Mine is a 3 Qt and I use an electric switch...
If you use a manual switch/valve, the accusump unit has to be mounted close enough for you to reach it every time you start/stop the car to turn it on/off. That is fine/no problems...except for the heat and the hassel.
BTW: I think you should use the 3 Quart unit....at least a 2 qt.
May 30, 2017 03:28 PM
ablaine
Nov 29, 2016 10:13 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
