camber curve
Old Dec 19, 2010 | 10:33 AM
balaguru's Avatar
balaguru
Default camber curve
Does anyone know of any camber curve plots for the front and rear suspension? I was wondering what the optimal ride height is for negative camber gain.
Old Dec 19, 2010 | 12:48 PM
terrasmak's Avatar
From what i understand the car needs to be run pretty tall, (dam near stock ride height) or you completely screw up your suspension geometry.
Old Dec 19, 2010 | 04:51 PM
hippie's Avatar
hippie
I measured them years ago....
https://my350z.com/forum/autocross-r...-curves-2.html
All of this was done with stock ride heights and upper control arm lengths.
To respond to your other post, I ended up making my own upper bushings for camber adjustment b/c there aren't any BSP legal aftermarket parts. (monoballs are still illegal)
Old Dec 20, 2010 | 06:55 AM
betamotorsports's Avatar
betamotorsports
A lot depends on the actual suspension travel. On stock spring I agree completely. With springs rates in the 700 to 900 range (an extreme example) you'll only see about 1" of bump and .5" of rebound travel so your camber curve/bump steer issue is very limited. It pretty easy to correct it the range of suspension travel is small.
Old Dec 20, 2010 | 08:51 AM
balaguru's Avatar
balaguru
Strong work!
Painful.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
