Autocross race alignment settings
Old Feb 23, 2011 | 03:05 PM
DivZero's Avatar
DivZero
Originally Posted by scotts300
RG6, so I won't arrive until the afternoon.
I might still be there then. It depends on how much homework I get done before then.
Old Feb 23, 2011 | 03:49 PM
JDMStanced's Avatar
JDMStanced
What about the caster? i honestly have no idea how much caster is good for DD and be competitive in autox. My current caster has different number from left to right (Didn't touch the caster adjustment on SPC arms)
Is the caster adjustment even necessary to be cmpetitive with BSP and BSP novice folks? If not, i can change my SPC arms (bad design) with Kinetix.
once again, sry for thread jacking.
Old Feb 24, 2011 | 11:23 AM
DivZero's Avatar
DivZero
I just got back from the shop and not super happy the results.
They put put front toe in instead of out, rear to in but .02 degrees different.
Front camber was -.3 on left and -1.3 on right. Lots of difference.
Rear camber was -.9 on left and -1.7 on right. Lots of difference. They said they was no more negative they could go..
They said they dialed in the toe and that's where the camber went.
I'll probably go back next week and have them fix it.
Also the parking brake doesn't spring down anymore either?
Don't worry, I talked with them and they know I'm not happy--I just had to get back to class so I couldn't have them fix it right then.
What do you guys think?
Also, what is the conversion from degrees to inches?
Old Apr 7, 2011 | 08:38 AM
mw9's Avatar
mw9
So in the front we are actually looking for toe out? Getting the car aligned tomorrow. Just put on SPL arms, SPL tie rod ends, SPL compression rod bushings.
Old Apr 7, 2011 | 08:40 AM
03threefiftyz's Avatar
03threefiftyz
I run .04 (on each side) toe-out in the front.
Old Apr 7, 2011 | 04:36 PM
JDMStanced's Avatar
JDMStanced
my left side of spl compression arms flunks insanely. how bout yours?
Old Apr 8, 2011 | 04:31 AM
mw9's Avatar
mw9
Is .08, 1/16in. I am getting the car done now.
Old Apr 8, 2011 | 08:07 AM
03threefiftyz
1/12.5....technically. 1/16 is fine.
EnjukuRacing
Sep 30, 2015 06:55 AM
