Sidewall size comparison
Old Nov 3, 2011 | 12:47 PM
solidfish's Avatar
solidfish
Default Sidewall size comparison
Are there any benefits in running larger/smaller sidewalls? I have two sets of tires, 245/40 and 245/45, and wondering which to keep. I know the difference isnt much, and if anything, barely noticeable as the 45s fill up the wheel well more.
Old Nov 3, 2011 | 01:04 PM
My bad. Did not notice this is the autocross forum.
Old Nov 3, 2011 | 01:21 PM
jnathan68's Avatar
jnathan68
Comparing different sidewall "height" on the same brand of tire, the less sidewall, usually the less deflection in the tire in cornering...basically a stiffer sidewall feel for the 40 series vs. the 45 series. This can make for a rougher ride but better cornering.
Also, a lower profile tire has a smaller diameter and thus, when talking about drive wheel tires, it changes the gearing.
I would go with the lower profile tire
Old Nov 3, 2011 | 01:35 PM
solidfish's Avatar
solidfish
Excellent, this is what I was looking for. I was thinking the lower profile would also help a bit with the reduced weight (as small as it may be).
Both tires are identical brand/model. Its the RE01s and they seem to have a fairly stiff sidewall, so I think I'll switch to the 40s.
Old Nov 3, 2011 | 01:58 PM
JCITY's Avatar
JCITY
I'm assuming you have 18" wheels?Keep in mind the correct diameter for your car.
The 45 series is the OEM size,the 40 series is still within the tolerance level and a bit lower profile.I sure would go with the 40 for the handling and the looks.Depending on the make of the tire,the ride difference should be minimal.
Old Nov 3, 2011 | 03:00 PM
betamotorsports's Avatar
betamotorsports
Lower sidewall height does not necessarily mean better handling. We got better lap times on high horsepower BMWs, Vipers, and 240Zs by running a taller sidewall height in back. That allowed the cars to put power down better and it was a bit easier for the driver to consistently turn faster laps. For the Solo2 FP national championship BMW going with a slick with a 2.5% taller sidewall pulled .1 seconds off course times.
Old Nov 3, 2011 | 04:07 PM
jnathan68's Avatar
jnathan68
So, for a amateur who doesn't have a lot of money to buy multiple sets of tires and do lots of back to back testing, is there a standard that can be applied...for example, lower sidewall in front and taller sidewall in the rear on a Z? Or, is it basically try and see which works best?
Old Nov 3, 2011 | 04:23 PM
betamotorsports
For most racers the 40 to 45 series difference we are talking about here would be unnoticeable. It comes into play at the upper levels of competition in your class or series. If you're a mid-pack competitor, work on your driving skills first.
Old Nov 3, 2011 | 04:37 PM
solidfish's Avatar
solidfish
Ya I figured 40 vs 45 would be negligible. Thanks for all the good info!
Old Nov 3, 2011 | 05:01 PM
terrasmak's Avatar
Run your 40's up front and the 45 in the back.
Old Nov 3, 2011 | 08:46 PM
SE5spd's Avatar
SE5spd
if its time for new tires just buy RS3s
