NASA Tire Rule Change
Why +6? It should be +4. That's what my TT director said. I asked because I wasn't sure. If it is 6 points, that is such a waste. That is why I am trying to mod my stock ones because it's worth 0 ponts. Make a lot of sense because the only reason we put aftermarket ones on is to gain camber. It says you can modify stock ones to gain camber and caster adjustment for 0 points.
Working on getting Delrin offset bushings now. I pressed my old Whiteline poly bushings out and sent them to a race shop in AL. I dropped them off to FedEx yesterday. They can use those as a reference for dimensions. Hopefully I can get at least a degree or so out them. That plus my car being lowered should put me about where I want and not have to take points for aftermarket A-arms.
