NASA TT Coilover help me
Old Sep 28, 2012 | 07:40 PM
lukerussell's Avatar
lukerussell
Default NASA TT Coilover help me
To stay in my class, I'm looking for a 3 point coilover (yes I know the spring adds 2 more). That means it can't have a piggyback resivoir and it can't have a shaft diameter 40mm or more.
That eliminates the bilstein b16 pss9/10 and it's close relatives. Eliminates KW clubsports and v3. I was originally looking at those.
So far my front runner is the tein type flex because I know it has a 22mm shaft.
Anybody know the shaft diameter on the tein mono flex? Looks beefy, but can't find hard specs. If its under 40mm, it's my new front runner.
JIC is coming out with new not quite ready stuff. The HKS, eibach, buddy club stuff I just don't personally know any serious racers that use it. Same w buddy club, Megan, bc cheapie stuff.
Anyway, if somebody has a mono flex shaft diameter measurement for me or a suggestion for something I may be overlooking, I'd appreciate it.
Old Sep 28, 2012 | 08:10 PM
03threefiftyz's Avatar
03threefiftyz
Double Koni's. The 8242's have a small shaft. It's the same as the OTS yellows.
Old Sep 29, 2012 | 02:27 AM
lukerussell
I'll check them out. Thx. Also aware of JRZ and Olin's but $$$. Also know of a guy with AST but they take time to build and I have a week. Ha.
Old Sep 29, 2012 | 07:51 AM
03threefiftyz
I'd rather campaign an event or two on stock shocks and get better components.
Old Sep 29, 2012 | 08:04 AM
kyoo's Avatar
kyoo
ASTs are pretty popular these days
Old Sep 29, 2012 | 08:16 AM
03threefiftyz
I use motons (now owned by AST). I am almost positive the ast's will have a larger shaft.
Old Sep 29, 2012 | 11:46 AM
terrasmak's Avatar
TTA or TTB ?
Old Sep 29, 2012 | 01:18 PM
03threefiftyz
My bet is TTC if he is so point limited.
Old Sep 29, 2012 | 09:36 PM
cyc5181's Avatar
cyc5181
What about TCKline with nismo? will that fit your criteria? just throwing out ideas, i know nothing about tt.........
Old Sep 30, 2012 | 02:35 AM
03threefiftyz
TCK's are Koni 8242's. Unless he gets very lucky in the marketplace both will hard too find. Neither have been in production in the last 5 years (unless you can get Nissan Motorsports USA to send you the springs).
Old Sep 30, 2012 | 05:48 PM
lukerussell
Yes, trying to stay in ttc. Have 255 direza, LSD, plenum spacer, sways, 9 pts by my calculations. I was wanting adj upper arms 4 pts and cheapie coilovers and springs, 5 points. Total 18.
I could do a nicer coilover w springs, 9 pts, skip the arms, the 1" drop will get me maybe -1.5 camber, not ideal.
I could do stock sways and just beef up the spring rate in the back, kinda makes sense, then I could do nice coils/springs and arms.
Or drop the plenum spacer?
Decisions. Ha.
Old Sep 30, 2012 | 05:51 PM
lukerussell
Anybody have any experience w fortune auto coilovers? Seems almost too good to be true for those prices.
Old Sep 30, 2012 | 07:01 PM
03threefiftyz
Momma always said, if it sounds too good to be true....it probably is.
Are you trying to be competitive? You won't be on star specs...assuming a strong region.
IMO drop the sways and plenum spacer. Run offset bushings in the front arms. Should give you extra points to run 225 A6's on a 9" wheel.
Old Oct 1, 2012 | 06:11 AM
lukerussell
and there it is, i like it.
Old Oct 1, 2012 | 02:41 PM
laze1's Avatar
laze1
Start with the Biggest Stickiest Rubber you can and work backwards from there...
Stevo Z
Oct 3, 2015 09:14 PM
