poly bushings legal in stock autox class??
Old Feb 13, 2013 | 01:11 AM
J 0 K 3 R's Avatar
J 0 K 3 R
Default poly bushings legal in stock autox class??
I dont think metal bushings are allowed in stock or street prepared (sp) autox classes in scca. Can i use whiteline poly bushings in stock? Or SP?
I only really want to replace the compression rod bushings and lca bushings.
Old Feb 13, 2013 | 05:38 AM
steidz's Avatar
steidz
Stock is stock so no it a no go, Poly is ok in everything else.
http://www.scca.com/solo/content.cfm?cid=44517
In some classes the ratio of poly to steel in the bushing needs to be comparable to the stock rubber to steel bushing.
Best to start reading the rules for stock class and then go to the class you want. dosent take long but not always real clear. If its not addressed its most likely not allowed.
Old Feb 15, 2013 | 06:31 PM
J 0 K 3 R's Avatar
J 0 K 3 R
Ok thanks. I just wanted to see if i could switch classes week to week 'easily'. I plan on getting non oem wheels and koni shocks. If i get the poly bushings it meams i cant run in whatever by just swapping wheels.
But i think i will.just.do sp and install my front splitter and cai.
