Track Day Z Project
#101
Have the rear back stays and first diagonal done. The rear back stays are not ideal but it was a compromise for my pushed back hoop design. Still complies with the 6" from top rule.
Broke my notcher, dumb mistake, taking a break till I get a new auger.
http://www.flickr.com/photos/60334063@N00/11840148914/
http://www.flickr.com/photos/60334063@N00/11840009823/
http://www.flickr.com/photos/60334063@N00/11840526466/
http://www.flickr.com/photos/60334063@N00/11840505976/[url=http://www.flickr.com/photos/60334063@N00/11840505976
#102
All the tubes are tacked into place for the rear half cage. Pretty happy with the final result. Can be a great base for a full cage in the future. Right now, this is perfect for me.
http://www.flickr.com/photos/60334063@N00/12019590065/
http://www.flickr.com/photos/60334063@N00/12020424976/
Total weight 55lbs.
Total weight 55lbs.
#109
Have some good updates! Got the cage spray painted, do you like the color? Was trying to keep it classy.
http://www.flickr.com/photos/60334063@N00/12442687575/
This tiny torch is great for the tight spots!
http://www.flickr.com/photos/60334063@N00/12442818753/
Welded in
http://www.flickr.com/photos/60334063@N00/12442677165/
Just about done now.
http://www.flickr.com/photos/60334063@N00/12443151774/
Welded in
#113
Looks good, not a fan of the bends in the main hoop. Wish I could work on my car.
#114
I didnt want to put the bar close to the seats, for the type of events ill be using the car for, I felt it would be more safe to have the bar back behind the driver rather than on the floor wrapped around the seats as normally done. It definitely was a compromise, but there is alot of bracing as well.
#117
Been nice here been able to test drive the car some.
Guys, having an issue with the fuel level gauge. I drained the tank completely when I started the cage build.
Put in 6 gallons, the pump clicked, level shows empty. Opened up both fuel tank hatches. Drivers side was empty and the fuel pump / pass side was half full.
Drivers side sender works, I moved it by hand the gauge works correctly.
Driving around didnt help at all. Trying to make to slosh back and fourth did nothing.
Why is fuel not going into the whole tank? Confused?
#120
on
superceded part number.....
25060CD00A $0.00 $0.00 $0.00
Electrical - Chassis electrical - Senders - Fuel gauge sending unit
Fuel gauge sending unit, 350z, right 2003 - 2006
25060CD00A $95.27 $0.00 $73.36
Fuel gauge sending unit, g35, coupe, right, part of fuel pump 2005 - 2007
Note there is another sending unit on the left side of the tank..
